Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Posted on Dec 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Multi color stripes on 60 inch sony wega, no picture
When I turned to tv on there was sound but no picture. The entire screen is very thin multi color verticle stripes. The tv is a rear projection 60 inch Sony Wega. It's a couple of years old. The screen does not change even when I switch input to DVDs.
  • krispickel Dec 19, 2008
    It's not under warranty anymore. Is this something I could possibly fix myself (I know nothing about TVs) or should I call in a repair person? Any idea how much a projection unit would run?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 247 Answers
  • Posted on Dec 19, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
247
Questions
Helped
118242
Points
719
It sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
  • Anonymous Dec 19, 2008
    you could call a repair man and he can take a look at it but if it is the projection unit replacing that might just cost as much as a new TV.
Sony trinitron srs wega 36 inch colour is going blue gone already is it worth fixing?
hello eightythreem!
some pro's and contra's...
Trinitron tubes are the best ever built picture tubes - long life, best contrast and sharpness, brilliant colors, etc thou u never get with any modern lcd screen. otherwise the big form factor is uncompareable with todays thin screens. also the brand itself and in your case the wega model is a name on its own high standard. anyway i would recommend you to let your tv check by a local service cause it sounds like a electronical problem - let them tell you how much aproximately fixing will count - before they repair it - so you still can decide is it worth or not. hope to helped a bit.
regards
My Sony Wega TV, KF 50WE610, suddenly will not display a picture when we turn it on. We have only multi-colored vertical stripes; however the sound does work. Our carrier is DirecTV. A second TV in the...
Hello there David,
How old is the tv? For the problem like this with the Sony Wega, you can do a power reset. Power off the TV and unplug the power cord from the electrical socket. Wait for like 1 minute, plug it back then turn it on.
If it doesn't work, then your Digital Mirror Device on the tv failed. You can call sony customer service at 1800 222 7669 to verify this hardware problem.
If you need further assistance, please let me know.
1helpful
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
2helpful
2answers
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
1helpful
Sony xbr 60 grand wega color problem.
It sounds like to me you have a bad Optical Block. It is a expensive repair and you may want to call Sony at 1800-222-SONY and see if the would assist you in repairs. Due to the age of it, they would probably only cover a partial amount of the repair.
Hope this helps,
Skyassoc
13helpful
2answers
Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Sony wega 61 inch (odessa, tx)
TV is a Sony WEGA 61" model # KDF-E60A20
2helpful
3answers
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
