Windows 7 Ultimate x64 seems to detect correctly drivers as installed. (VIAVT1708S_Audio_V6017100_Windows7_WHQL) but no sound comes to speakers nor headset in frontal plug. (of course I tested speakers and headset with another device and sound is ok). Also nvidia geforce 9600 GT hdmi audio device is not detected.). No error or another misfunction, Only no sound.
Hi sir/madam
First uninstall audio drivers which u installed.
Then download the drivers
Try this link from original site
https://www.asus.com/Motherboards/P5Q/HelpDesk_Download/
There download only audio drivers and install it..
If still not works , reply me
SOURCE: Audio Hardware Detection
check the website for newest drivers if not you have to reinstall then install sp3 and hope your drivers work again. or just stick with sp2.
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
SOURCE: audio device p5ad2-e deluxe with windows 7
This worked for me. You need the sound drivers for the "Intel C-Media High Definition
Audio CMi9880".
I went to this sight www.softwarepatch.pl/plikd.php
Its in a different language but click on the box.
i downloaded the audio file called UDAX008(Logo56.62).zip.
Click on the box, and downloaded the zip file.
Unzipped it.
Then change the compatibility mode of the Setup.exe file to Winxp Sp3 by going to the properties of the Setup.exe file and click on the Compatibility tab. Check the box for "Run this program in compatibility mode for". And change it to Windows XP Service pack 3.
The drivers are actually meant for windows xp but they are working fine for me and im very happy now. I was worried like you. I hope it works for you.
w w w . s o f t w a r e p a t c h . p l / p l i k d . p h p
SOURCE: ASUS P5GD2 Deluxe motherboard with no sound
This is a known isue and ASUS is working on a sound driver for the chipset. Keep checking their site for driver updates. The board should all install with Windows 7 except for the sound drivers. Some people say they can install the vista driver and run it in vist or xp compatibility mode. The other thing you can do is pick up a cheap $20 Win 7 compliant sound card till the chipset driver issue is resolved.
SOURCE: I just install windows 7 OS but no audio, where
Go to the following DriverEasy website, download and install. Follow the instructions and it should allow you to download and install the correct drivers for your Motherboard. Much easier than trying to find the drivers on the ASUS website.
