We cab clean the glass at the outside, and we can clean the glass directly inside the oven. But the glass between need to be cleaned. Can I unscrew the door? Will that allow me to access the inside window?
Below are instructions on how to take your oven door apart to
remove any stains that may be caught down in the door vents. Tools needed: good Phillips head screwdriver or small quad bit
driver. B. With door in broil stop position lift door assembly off
hinges. C. Lay door on table, position so that handle hangs freely over
edge of table D. Remove 2 screws and washers that secure handle to lining
assembly. E. Remove 8 screws that attach textured steel door wrapper trim
to lining assembly 3 at top, 3 at bottom, 1 on each side F. Lift door lining up and out of wrapper trim assembly. G. Lay lining assembly on table with wool shield/inner part of
lining facing up. H. Remove 2 glass clamps via 2 screws per clamp. These clamps
attach innermost clear glass to wool shield. I. Lift out center clear glass from wool shield, this glass
just lays onto the wool shield and is held in place by the glass/ clamps in
item
H.
K. One glass that remains in door lining assembly can at this
time be cleaned without further disassembly the lining assembly. L. Reassemble in reverse order.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
The oven door keeps coming open when cooking and the speed bake goes off and the oven light comes on frigidaire gallery electic oven thxs dave
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
SOURCE: lost manual to my electric oven, how do you clean inside of oven?
Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
the oven will clean itself with high temperatures.
HEre is a manual for a frigider oven, should be not too different from yours.
SOURCE: cannot unlock oven frigidaire electrolux gallery series
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
SOURCE: I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
hello. this is a common problem. here is a link to provide you with an owner manual which explains how to use the self-clean function
http://www.frigidaire.com/manuals.aspx
and here is a link to speak directly to the folks at frigidaire who will talk you through the solution to your problem
http://www.frigidaire.com/contactus.aspx
let me know how u make out with this as I can offer additional help if needed.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
I hav a electric pro line oven with gas top my handle has came unscrewed from my oven door and I carnt screw it back on cause the inside has the glass in the way of the screws
