There is a capacitor in the top of the machine to check/ replace and connections from the timer to check.
SOURCE: how to reset or unlocked the beko washing machine timer
Try unplugging the machine for 5 minutes, if that doesn't reset it you likely have a defective main control circuit board.
SOURCE: beko not draining and spinning
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Also must check water level device,if You do not know what is this or where is on machine then call a service.Maybe the hose is precipitate from device.
SOURCE: beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
SOURCE: beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
I emptied the filter and found a bra reinforcement. Machine now works. Thanks to all!
How do you empty the filter?
does not start switch keeps flashing
