The manual states 215 watts per channel @ 8-ohms and 450 watts @ 4-ohms. This isn't correct is it? I've read, from a couple of Guitar Center Employees that it's incorrect. I want to run 2-sets (4 speakers, each @ 8 ohms 800 watts 400 rms, daisy chained) out of this unit but I am afraid of the incorrect information in the manual. Does anybody know the true specs? According to the specs, I can't even run two of these speakers (one on each side @ 8-ohms) because it's only rated at 215 watts per channel @ 8-ohms.
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
SOURCE: I Have a behringer pmp3000 16 channel mixer amp.
As a test, plug ONLY into the RCA stereo inputs and test for equality. Have no other connections when testing other than the speakers. Make sure the Speakon cables for the speakers connect correctely and that the
This unit has some TRS inputs and one must use cables designed for that. Often a person may plug a mono into a TRS inout and the barell of the mono grounds out the ring of a TRS connector. Make sure the slide switch is clear up to Main L and Main R position.
The amps in these units are "class D" which are like the Peavey DECA amps, that is are switching type with filter. They are very efficient pwer wise. They usually are all there or totally dead, not just weak.
Make sure you do not go below the load resistance they specify. (Usually 4 ohms)
The power supply is a switching regulator and has lethal voltage present so use caution if you open the unit. They are hard to work on and Behringer doesn't supply schematics. I had to trace out the circuitry in a PMP5000 I repaired.
SOURCE: hi i have 2x ev sx300 speakers (speakon) and 2x
Yes, you can put two 8 ohm speakers daisy chain per side MAX. The Speakon should have ONLY two wires on the +1 and -1 terminals unless you are using bridged mode which is NOT applicable in your configuration of speakers. Also be careful is you use any 1/4 inch speaker plugs in the sytem as the SLEEVE, not the TIP of channel A is the "hot" lead... get this to ground someplace and goodbye amp.
SOURCE: im using a behringer ucg102
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
