Washing Machines Logo
A
Anonymous Posted on Aug 16, 2012
E10 error code on Frigidaire affinity how to repair it
  • Official Brand Answer 4,342 Answers
  • Posted on Aug 20, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466587
Points
5907
Your fill time, water fill time, is too long. Have a professional complete the following:
. Is the incoming water flow normal? Yes, go to step (4). No, go to step (2). 2. Are the incoming water faucets turned on? No, turn water faucets on. Yes, go to step (3). 3. Is the incoming water pressure above (30) psi? No, have customer correct pressure problem. Yes, check for kinked or blocked incoming water hoses, clean incoming water screens. If problem still remains, replace the water inlet valve assembly. 4. Does the fill water continue to enter the washer? Yes, go to step (5) no, go to step (6). 5. Remove power from washer. Did the water fill stop? Yes, go to step (6). No, replace the inlet valve assembly. 6. For Better models, check the electronic pressure sensor. For Good models, check the pressure switch. Pressure sensor checks good. Go to step (7). Pressure sensor checks incorrect. Replace pressure sensor. 7. Replace the Main Control Board
5 Related Answers
A
Anonymous
  • Posted on Sep 09, 2007
SOURCE: AFFINITY ERROR CODE
door not close
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Anonymous
  • Posted on Feb 12, 2009
SOURCE: Frigidaire Affinity Error Code EFO
We got the same error. After searching countless forums, we found the solution! There were socks/underwear/change built up in the pump. The water was not cycling through properly. It didn't even get passed the wash cycle. Cleaned it out and everything works fine. Plus, the error code list is INSIDE the washer! Go figure.
Anonymous
  • Posted on Sep 26, 2009
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Anonymous
  • Posted on Dec 03, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Frigidaire Affinity ATF6000ES error code E10
Hi - Typically error code E10 indicates that water takes too long to fill. Contact a professional to run multiple tests to verify the incoming water flow is normal and to check the electronic pressure sensor. Depending on the results, washer may possibly have a faulty water inlet valve assembly, pressure sensor/switch or main control board.
1helpful
2answers
E10 on my Frigidaire Affinity Front Load Washer
just go to fridge website support center and see what the code is or google Frigidaire code 10
4helpful
What does the code E10 mean? The washer flashes that code and won't spin.This is and Affinity front load washer.
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
4helpful
Error code E10 what is it
Thank you !!
My Frigidaire Affinity Model atf6000fs0 Washer presents two error codes at beginning of each cycle - EF0 after about one minute and the E10 after a few minutes - cycle stops there. Nothing else happens....
My Affinity (M - ATF6000FS0) fails to an E-20 code. The troubleshooting guide helped; however, the code continues to come in. The drain line is clear to the pump, but the pump sounds like it is failing. Guidance, insight, feedback....please!
3helpful
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
1helpful
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
3helpful
3answers
E10 error code?
We had the E10 error code. I took off the water intake hose as the washer and the screen there was full of sand from our well. I cleaned the screen out and the code disappeared.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
