SOURCE: hp compaq nx6120 drive problem
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=457952&taskId=135&prodTypeId=321957&prodSeriesId=457951&submit.y=7&submit.x=10&lang=en&cc=us
There u go!, select your OS and dowload the drivers you need
Nic
SOURCE: problem vd hp compaq
choose your OS on the following page for the right drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=447347&taskId=135&prodTypeId=321957&prodSeriesId=447346&lang=en&cc=us
SOURCE: HP Compaq nc 6120 - it is stuck - curser is halt
sounds like you have something stuck on your touchpad controller.
You could plug in an external mouse and try to shut off your touchpad while putting pressure on the case long enough to get to mouse file in your control panel folder.
You will probably have to take the cover off and look for stuck switches or maybe something spilled on the touchpad itself that is gumming things up.
good luck and be careful.
SOURCE: WHEN MY HP COMPAQ NC 6120 BOOT UP IT ONLY STOPS AT
You need to perform a Hard Reset and a RAM remove and reseat.
But Unfortunately I think its a hardware issue.
If the notebook is under warranty The best option to contact HP right now if not in warranty then contact Best Buy
SOURCE: how can download net driver laptop hp compaq 6120
Hello, kindly get it here :
www.hp.com/cposupport/eschome.html
www.techno-files.com/categories/laptop/531.html
www.welcome.hp.com/country/us/en/support.html
Regards,JAy
You can download the drivers from the Compaq/HP WEB
support/download page. Make sure you select your model laptop and the XP or
Vista Windows version of the drivers you require and install them. Click on
this link to download the drivers: -
www.compaq.com/country/cpq_support.html
activation key......see d back of ur laptop
