JVC GR-D350 Mini DV Digital Camcorder Logo
CANDISHA TURNER Posted on Mar 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camcorder problems
I haven't used my camcorder for a while so I charged the battery for use. When i turned it on it keeps telling me that it's in safety mode and reattach battery. I did that several times and its not working. Can you help me?
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 158 Answers
  • Posted on Aug 14, 2007
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
158
Questions
0
Helped
43745
Points
240
Clean contacts on battery and camera if the battery is charging properly then get a new battery and charge this one and if same resaults then have camcorder repaired check if you have got power using power lead from mains adapter it maybe contacts problem with unit and external power. hope this has helped
How to fix a Canovision 8 VM-E1 camcorder?
replace the battery by the new one.
Camcorder wont turn on at all
Are the batteries fully charged ?
2helpful
Camcorder problem
If it is not battery fault then its charging IC or fuse damage.You can also use external charger to charge the battery
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
    • If the problem persists using a different battery, service may be required .
19helpful
5answers
Insignia 5.0 mp hd camcorder. How do I charge the battery?
Make sue the text side of the battery is facing up. Not the pure black side... I was having this problem until I decided to flip the battery around and it worked just fine...
Jan 09, 2009 • Cameras
Camcorder will not power on
How can you describe something at least nine years old as 'new'? Be realistic, please.
Battery Charge Light not working & can't display battery info
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
2answers
Battery Won't Charge on JVC GZ-MG275
The only suggestion is that it's a faulty battery. You said the camcorder is new, take the battery back, it's under waranty, and get a new one.
What is the purpose of the switch on my camcorder battery?
This switch does not operate any function on the battery. It is simply used as a self reference tool. You can switch it to RED to tell yourself it’s charged and BLACK to tell yourself it’s un-charged.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
