Canon Digital Rebel XSi Digital Camera Logo
rick Posted on Jan 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Err 01 Communication between the camera and lens is faulty
Below is what happens occasionally...An error pops up on the display. Err 01 Communication between the camera and lens is faulty. Clean the contacts. I have tried to clean the contacts with isopropyl rubbing alcohol and was told to use a rubber eraser as well. Both have been tried with no luck.
TC CAMERA REPAIR.Com
Level 2:
  • Expert 176 Answers
  • Posted on Feb 01, 2018
Expert
Level 2:
Answers
176
Questions
Helped
78794
Points
276
Most of the Time when this happens it's the curcuit board inside the lens that bad from use, Needs to be replace by a repair Tech! Try a different Lens to confirm that! TCCameraRepair.com
2 Related Answers
Anonymous
  • 153 Answers
  • Posted on Mar 03, 2011
SOURCE: when i try to take
This is a basic fix, but have you removed the lens from the camera body and reattached it all? Check all of the connections while you're in there. Hope this helps =]
Anonymous
  • 11967 Answers
  • Posted on Oct 15, 2011
SOURCE: how to repair err 01 on canon 1000d "Communication
So, have you cleaned the contacts? Remove the lens and using a cotton swab lightly dampened with rubbing alcohol, clean the contacts on the lens and the camera body where they meet.
I keep getting Err 01 and no photo is taken what do I do?
ERR 01 is a lens to body communication error. Clean the lens and body contacts (put a small amount of alcohol on a Q-tip - do not use rubbing alcohol!!!). Try again. If that doesn't work, problem may be in lens or body. Using the flat of your fingernail, push in the contacts on the body inside the mirror box to clean any tarnishing between the contacts the the circuit (they are spring loaded). Try another lens - if the other lens works, then your problem is in the first lens. If it still gives the ERR 01 code then the problem is in the body.
Has the camera been impacted or had water/liquid spillage?
Error 001
Err 01
Description: The communication between the camera and lens is faulty.
Resolution: Very gently clean the electrical contacts (highlighted in red) on the camera and the lens using a clean and dry cloth.
Err 01....communication between lens and camera is faulty.Please clean the lens contact...this is the error message...please say a solution..
The contacts are the little gold coloured metal squares that touch between your lens and the body. Clean them with isopropyl alcohol (moistened glasses wipes work well) and see how you go.
Err 1 message
Err 01
1helpful
Error 01 in canon eos 5d
Err 01: Lens to body communication error
1.The camera to lens communication is somehow being interfered with could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts,
2. Check the lens and the contacts
3. Also check below link if you need a canon eos 5d service manual
http://goo.gl/1rXwuc
thanks
2helpful
How to repair err 01 on canon 1000d "Communication
I have the tamron 18-200 mm XR Di-II if macro lens. The camera displays the error Err 01 Communication between the camera & lens is faulty. Clean the lens contacts. This error...
So, have you cleaned the contacts as you were advised? You do this by removing the lens and cleaning the contacts on the camera body and on the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 19, 2011 • Cameras
3helpful
2answers
Canon Rebel XS - Lens EF 75-300 1:4-5.6 III - err 01- comm betw
As a first step have you tried CAREFULLY (to avoid eraser bits getting inside the camera) rubbing the gold contacts on the camera and lens with a clean pencil eraser? That's one of Canon's recommendations. Good luck.
5helpful
Canon err 01
This error means "Communication between the camera and lens is faulty. Clean the lens contacts." If you are using the same lens on both cameras, the problem is with the metal contacts on the rear of the lens where it communicates with the camera body. You can gently clean these contacts by using a clean pencil eraser. Make sure you hold the lens "bottom down" as you clean it so that the eraser debris falls to the table instead of inside the lens!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
