When I run any program that includes a drying cycle, the machine runs as far as the end of the rinse cycle but then seems to get stuck with 1 minute showing on the clock. It is making a slight noise at this point, but it does not sound like a water noise and if you open the machine, the water appears to have drained out. A reset (A + C buttons) is the only way of stopping it, but the contents have not been dried. I have cleaned the filters and cleaned a small amount of debris from around the pump wheel which runs freely, but it doesn't seem to make any difference. Are there any sensors I can clean/check, or is it likely that the control board has a problem? How can I tell?
Does this unit run for hours with 1 min remaining? if so you need to replace the controll board. I have soldered some with sucess but it "Should be replaced" You also need to make sure you have just dry liquid in the unit and "Don't use soap tabs" 1 -3 tsp of soap that is all. If you are good with mech work I can walk you through the way to check ths unit out to tell what the problem is.....
