What could be the problem with my printer konica minolta c350?
SOURCE: konica minolta opc drum magicolor
When you print stop the printer half way through then check the image on the opc drum and transfer belt to see if it's complete or not, also you may want to check the aidc sensor (sometimes the cable comes loose). I can e mail you the 2300 series service manual (4.17mb) if you reply with your e mail address
SOURCE: I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
SOURCE: Only prnting the startup page every time I send a document to print
This is likely a problem with the printer driver or the printer spooling system on your computer. Check in folder "C:\Windows\System32\spool\PRINTERS". If there are files in this folder at any time when you are not expecting a printout and there were no system messages, then it is confirmed.
The easiest thing to try is to uninstall and reinstall your printer drivers. If that does not do the trick and a problem with the printer spooling system, you might be able to try uninstalling and reinstalling this feature. If this does not work or you cannot do figure out how to do it yourself, you will need a Windows expert to fix it for you.
SOURCE: Di351f. Can not print over the network.
I am confused. If you can see the printer via the web browser and you can print a window's test page you are all set up and ready to print. There should be no problem printing as long as you have that printer selected as the default printer and it is selected in whatever program you are printing from. What do you mean by "straight over the network"
Testimonial: "This was helpful because I got the printer working. I made me take another look at the installation and enter the right settings and port number in."
SOURCE: Konica Minolta 2300w starts it print approx 10cm
Needs a good cleaning to remove loose toner, and with the fuser access door open there's a solenoid inside that needs cleaning and slight adjustment. If you're not familiar you might need a shop to take care of it for you, it's a common problem with this machine.
Select your printers properties
Duplex printing
You can print a document onto both side of a page. This comes in handy
when you want to bind multiple-page documents.
1 Click the Layout tab.
2 From the "Double Sides" drop-down list, select "Double-Sided".
Note
The binding orientation can be specified from the "Binding Position"
drop-down list.
