How much oil is needed in my mtx 125 forks
SOURCE: how much 5w oil goes into each fork?
Using 5w oil with stock springs, your oil level should be about 100mm from the top with the fork fully compressed, damper rod pushed all the way down, and the spring out. I hope this helps and good luck. Please vote and leave a message.
SOURCE: Front fork oil capacity
Hi Lukepentcof.
its 350cc or 11.8 ounces in the Clyma book, but that's for a 1986 onwards model. you can vary the amount you use to suit your style of riding anyways. I doubt it would be that far from the mark.
regards
robotek
SOURCE: Fork Oil CBR954
There are three most common weights of fork oil. 5W is a light oil for a smoother ride, 10W is a heaver oil for stiffer suspension and 15W is mainly used for a stiffer ride such as racing. I have found 20W and 25W oils but they are not that common.
If you are a pleasure rider 5W or 10W would be the right oil for you. If you are always "in the twisties" and riding the limits of the bike, go with the 15W.
Will any honda 125 cdi work on my mtx
