We cant see this effect on small areas but it is very obvious on large areas of solid colour
What is the color of the streak
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: 2430DL
You probably have dust or toner particles on the laser lens. Take out the drum unit and wipe the laser lens with a clean soft cloth.
SOURCE: poor color quality
find out where are the streaks come from, from PC drum, or transfer belt, fusin unit or from toner cartridges. does the trasferbelt and PC drum look okey. finally if nothing is helping, try firmware upgrade and replace printer drivers, sometimes help.
SOURCE: streaks on printed page full length even after installing new cartridge
Check the glass (the one the paper rests on). The underside of the glass that is. This is what the light 'sees', so, it will print this!
SOURCE: Our 2300DL is leaving streaks when printing
Out of one or more toners. If you have removed and replaced a cartridge in error the % remaining is reset to 100%. Try to determine which color is missing in your print out (usually black), and then follow menu instructions to replace that cartridge. The ends are color coded so be sure you change the correct one. This will insure the remaining cartridges % remaining is correct.
SOURCE: I have a 2590MF, when i print colour pics there
Dirty
print out is basically due to cartridge related issues. Take out the
cartridge and clean its drum/ (green roller) with a dry, soft,
lint-free cloth. The drum is usually located under a cover. Checkout for
any spilled toner inside the printer and clean it also. Print a few
pages so that the parts get further cleaned. I think, this would solve
the issue. (This may help temporarily)
Moreover, streaks
(thicker lines) and dots etc indicate faulty PCR Roller which is located
behind the
green drum inside the cartridge.
So, it is recommended that you replace the cartridge with a genuine one (not any replacement or refill).
Let me know if any
further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
