Avaya 4610SW IP Phone Logo
Tafat Alvarado Posted on Aug 15, 2012
Enable mute button on avaya - Avaya 4610SW IP Phone
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Dec 12, 2012
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
9668
Points
24
Just factory set it to default and it would work. Be mindful of the settings though as your avaya might not work properly. Write down all those IP settings and others to make sure it would work still.
A
Anonymous
Press it. There is a button below the headset button on the 5610, labeled MUTE.
Reset phone
Did you try
Mute 7 3 7 3 8 # (Mute R E S E T #). NOTE: Press the Mute button momentarily
Apr 30, 2014 • Avaya 9640G
How to mute ring
My office phone is similar and it has a long volume button, as well as a mmute button on the lower right side, along with all the other buttons.
How to put avaya telephone on mute mode please..
Which phone? You list a 5400 series. That has a mute button on it. Just press the mute button.
Hard Reset Avaya 1608 IP Phone
AVAYA 1608 I (RESET)
REMOVE THE CABLE AND RESTART THE PHONE ONE'S IT RESTART.
YOU WILL SEE THIS IN DISPLAY" *program" AT THAT MOMENT CLICK " * BUTTON ON PHONE"
THEN TYPE " 27238#". SO IT WILL SHOW THE SETTING'S OF PHONE THEN CLICK " # " UNTIL YOU REACH TO DISPLAY SHOWING " command" TYPE THE COMMAND AS " PRESS MUTE BUTTON AND CONTINUE 2723825327 # " THIS WILL REACH TO SHOW IN YOU DISPLAY TO CONFORM THE RESET CLICK "# TWO TIME" THEN IT WILL BE RESET.
1helpful
Have Callmaster lll phones. We want mute button disabled. Agents have figured how to enable the mute buttons on individual phones. Looking for way to permantly disable mute feature on 700 phones. Thanks
First make sure headset/handset adaptors are not plugged into the phone
Press Select
Press Mute
Dial 68 (this will show the current setting)
Press * to change the setting
When the setting is at what you want press # this will save tyhe setting and exit programming mode
Hope this helps.
7helpful
Is there a mute button on avaya phones
The Mic/HFAI button mutes the microphone when on speaker.When the light on the mic button is off the microphone is muted and vice versa.
Inbound call on avaya - phone on mute and you hit the headset button by mistake = will it record that you disconnected the customer? I got fired for hanging up on customers with the Avaya hard phone and...
No, that will not disconnect the caller. BUT, if you hit the headset button again, it will.
If you hit the headset button, you need to hit the switch hook to regain the call....
4helpful
2answers
Avaya 5610 IP Phone
Press mute reset (mute 73738)
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
