There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
The problem is a
rubber tape tension roller. Simply eject the tape, look inside where the
tape goes. You will see a black rubber cylinder that may have a white
plastic tube protruding. If you have long tweezer or a hemostat remove
the plastic tube which hold the rubber tensioner in place, then remove
the rubber tension cylinder. Clean the shaft of the black rubber
tensioner with alcohol on a q-tip. Replace rubber tension cylinder and
plastic tube.
Also, the tapes can cause the problem. This
process is possible by one person, but you may need another person or
have three hands. The C:31:23 is tape tension error. The tape has
become stuck. Simply eject the tape. Holding the tape upside down, pull
back on the tape cover release slide on the left side of the tape, now
take the hemostat and push the tape release tab, located opposite of
the tape cover, push this tab down and back toward the back edge of the
tape. Now while holding both those release levers, take a pencil and
wind the tape past the bad spot or until the tape winds freely. I did both of these and was able to use the camera again and view all my tapes! Good luck and QUIT SPANKING YOUR CAMERAS!!!!
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
you try to eject the tape. You may be getting an error code that indicates the
reels are not turning for some reason. You can assist the reels turning
as the tape is ejected if you stick a small plastic pick or a toothpick
into the reels to assist the reels turning and then you may be able to
remove the tape.
it might not be campatiable with windows vista,i have windows vista on my laptop and i have to watch out and make sure it works with vista,some do ,some don't.
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
This mceahnism is now defective and only a skilled workshop technician can do this job.
If you need the service manual and parts we can help.
Siva
[email protected]
