I have a liftmaster. Both the amber and green led are on and steady, but the @#% door still won't close. It was going about 90% down before returning. I tried closing and opening manually and now it won't close at all. Both my wife and I verified that both l.e.d.s are lit and steady...
SOURCE: 1/2 hp liftmaster closer stalls while closing in cold weather
Make sure your force settings are at least turned up to 5
SOURCE: My Liftmaster garage door opener will not close
You have a problem with the safety eyes. Make sure both eyes have a lit Led light, if not realign sensors
SOURCE: Chamberlain Liftmaster 1246R won't open/close
if youcan hear the motor turning when you hit the remote or wall button the plastic gear in the oprator has been ripped and if you take the cover off you will see all of the whote plastic dust that has come from the gear being shreded. You can replace this gear. you do not have to buy a new operator. it is very easy to replace this gear. I can't tell you were to buy one because I buy all my stuff from a dealer.
SOURCE: Liftmaster garage door will not close from the remote in the car
Hello, friend, W/D here.
I saw your post; I haven't seen the one you referred to. I have had similar issues to your's and here's what I did:
Having to hold the button down the entire time indicates that either your photoelectric eyes are out of alignment, or one of them has broken. If broken, the light on it will be out. Sometimes you can tighten the wire to repair, and tapping on it a bit won't hurt it. Adjusting the alignment is a bit of trial and error, but a string line helps to get them close. You can again judge by the light on the cells.
Not close from the car......started out good, got weaker... Same for me....new battery fixed it. I think I had to reprogram the remote, and the instructions were on the back of the lift motor in the garage....
Testimonial: "Thanks. When I looked closely,the amber light was lit fine, but the green light was flickering so I tapped it until it was solid - now it works fine."
SOURCE: Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
