My mp player was working until recently when I added new songs, now when I turn it on it says"incorrect format, reformat the player", How do I reformat the player?
If your adding music to the device and its not playing, its because your audio files are not the correct format. This unit only plays MP3 audio or Uncopyrighted Windows Media Audio files. You can test this by connecting the MP3 player, copy one of the sampe audio files under 'My Music' location on your computer and paste it on your mp3 player. It will play the audio fine.
How to play: Hold in play button until red ligh is steady, then press Play again to start the audio.
Make sure you remove any audio file that is not the correct format.
to check format of song:
right click the song, go to properties, under properties it will say 'Type of File', make sure this says MP3, thats the safest way to go.
make sure what your putting on is MP3 or unprotected WMA files. If the light is blinking, then it means its playing the song, if you hear nothing, the audio is not in the correct format.
There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites. WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers. You can also format the player in Windows Media Player itself: Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything. -Tha Mp3 Doctor
The songs that you loaded onto the player are not in the correct format - iTunes, DRM-encrypt. WMA are not allowed, for instance. Convert everything to mp3 format. It is asking you to reformat the player because it wants you to delete the wrong-formatted songs off the player. I would check your user manual to find the best way to reformat.
In general, though, there are two ways to format an Mp3 player - one on the computer
The Sandisk site says that your dad's device should play .wav, .mp3 and .wma files. Has the player EVER worked? I got a C250 for my wife as a Christmas present and my computer recognized but refused to communicate with it UNTIL I DOWNLOADED AND INSTALLED THE FIRMWARE UPDATE. The player was a paperweight until then. It turned on and played the demo files pre-loaded on it, but I couldn't transfer a single file into it. Just a thought. Here's the link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
good luck.
groove_guy
hmmm i'm not familiar with the problem but try this.
First open your mp3 player and go to settings. Under the USB menu
change it to MSC. Then plug in the mp3 player to the computer. Open
the My Computer on your desktop, right click on the Sansa mp3 player
and click Format. Make sure Fat32 is checked and Quick format is
UNchecked. Then format the mp3 player. After that it should be clean
and work just like a USB drive.
I"ve been waiting for their responce,if it comes?
