Have tried changing batteries in both car & keyring? tried keyring under the dash & also leaving key in on position for 30mins but I still can't unlock doors & the dash lights won't come on for the car to start. I do have power as the windows lights & stereo all work. Thankyou
SOURCE: electronic immobilizer
most likely cause is the gauge cluster, this will have to be tested and service by your local dealership because the dash cluster and keys have to be coded. I have seen the immobilizer loose it's coding for apearantly no reason. therefore have them recode cluster and see if problem goes away, if it doesn't the gauge cluster will have to be replaced.
SOURCE: Battery is fine, no dash lights come on car won't start.
check fuses for dash lights if you use a12 volt tester turn on runnig lights and check dash lite fuse for power the radio maybe on same curcit/
SOURCE: 2005 Mazda 6 Immobilizer System
try the spare key if the problem still persist .
then you have to diagnose the immo system by scan tool to know which DTC is recorded
SOURCE: 2000 Ford Taurus Battery Drain - - After the car
using a test light with all doors closed everything in the car off; disconnect your black battery cable then: connect a test light between the battery post you just removed the cable from and the cable you removed; the light should light. this is your short (leak) then remove fuses until you find the fuse that causes the light to go off your problem is in that circuit.
SOURCE: my renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
