Chirping
Check power supply and
Flyback Transformer
So how do i check the power supply? I have been looking for info and parts for this TV but not found much yet
No, i dont work on TVs but i do work on high and low votage cuicits at work I think i can handle this with some help. After cleaning the dust and dirt off it seems to be OK .no burns or cracks.and there are about 4 transistor .they also look OK .im not sure witch is the horizontal output transistor? and the TV is RCA F32TF720 not a RCA 32F531T 32.
So I replaced the horizontal ouput transistor and now it appears that it is trying to start or turn on when i pug it in ,the LED for the on button lights and the gos out, on and off by its self for a few ,also I can hear a very faint chirp each time and then it stops.Do you think it is the flyback transformer?
turn the back off ( screws first ), have a multimeter set to 250V dc, Black wire to ground
some of the components are similar on the link i have provide above
post voltages on the CRT socket pins
main board will be later
inspect flyback transformer for possible cracks , buldge capacitor,
check horizontal output transistor
Do not do these , if you have not done it before. and feel you cant.
have you seen the link above?
did you click on it .... flyback transformer
here is the link
http://www.fixya.com/support/r13832793-t...
the horizontal output transistor is the second image from the top of the page
just in case you need parts here
http://www.partstore.com/Model/Thomson/R...
The HOT tested bad got one on the way we will see if that is all.Thanks for the help and i will let you know
On most it is the collector and emitter, thanks for choosing fixya for assistance
you are always welcome!
read the starting line of my tip:
a) Basically it has to be acted upon by a supply voltage of at least 95V to work.
another on d)
d) Having a B+ voltage reading of 75 V or lesser ( primary pins )
indicates a bad or partially shorted flyback,
assuming your horizontal output transistor
and power supply are good and OK
