SOURCE: brige mode
hi Fip,
Here is a link, Step by step!
http://www.siemens.com/index.jsp?sdc_p=ft4mlsuo1274280n1274280i1272700pc9z2
Good Luck!
SOURCE: Static Ip with Speedstream 4200 Modem
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
SOURCE: Placing Sppedstream Modem 4200 in bridge mode
http://192.168.254.254/brgmode.html ...or if they have the gay firmware >.> go to http://speedstream/brgmode.html then click apply....now set your router to log in with your user information with a PPOE login...if your like me and using the dlg-4500 just go to setup and do internet wizard to set up easily...then your ready to go... it can take up to 10 minutes for your router to configure so give it time..and if it doesn't seem like it's working in that time...try cycling your power then check again...and if still not working, do a hard reset (hold reset till lights alternat from green to red) to reset to factor default (do it for your router too becfause it will still be set to sign into your isp for you)
SOURCE: How do I put a siemens speedstream 4200 dsl modem in bridge mode?
go to the link below it is all explained step by step there. http://www.thevoipstore.net/how-to/setup-an-optus-speedstream-4200-modem-in-bridge-mode.html
