I need to replace HD-1688 in wall clock, where do I buy a new one?
Who sells HD-1688 replacements? I haven't the patience to fix since head injury just want a new movement for Steelers wall clock.
    New Friend:
Hi Mojo...
Replacement parts you can find here Amazon com HD 1688. Click on the link and pick one (who fits the most).
I hope it was helpful.
Enjoy
Posted on Nov 19, 2014
    New Friend:
Here my friend: Amazon com HD 1688
Posted on Oct 12, 2014
    New Friend:
The best dial on amazon, definitely is Quartz Clock Movement Mechanism DIY Repair Parts White Hands . Take a look. I need to replace HD-1688 in wall clock, where do  - need-replace-hd-1688-in-wall-clock-buy-sk11hjpjmetbylcvfhievebb-1-0.jpg
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Within few seconds for Android on this web page. https://browsys.com The SuperSU Pro is the most tap on it to Install the SuperSu Pro App. .
Posted on Dec 01, 2017
    New Friend:
    Welcome Back:
  • 5 Answers
Mobdro Apk is a live video clip streaming application that helps Mobdro alternative that allowed us see any video clip streams.
Posted on Oct 26, 2017
3 Suggested Answers
SOURCE:
krb55
  • 604 Answers
SOURCE: looking to replace an electric movement for a ship
go to www.klockit.com they make replacement movements of many types
Posted on Mar 17, 2011
gopakumarg43
  • 76140 Answers
SOURCE: We now have two wall clocks that have stopped.
Hello
Check its battery contacts for any rust or dust. Anyway clean it well and put the pattery, and check whether it is working or not.
Battery - The La Crosse Technology clock must have a fresh battery to receive and process the time signal.
Location - Try a different location, ideally near a window. It should be at least six feet from computers, TVs, air conditioners, other Radio-
Controlled clocks and other electrical appliances that cause interference.
Weather - Electrical storms between you and Colorado during the night will interfere with the WWVB signal.
Although we cannot control the weather we can help you predict it (see www.lacrossetechnology.com).
Daylight Savings Time
The National Institute of Standards and Technology and WWVB encode a special DST "bit" in the WWVB transmission for DST. Your La
Crosse Technology clock will read this information and automatically advance the hands one hour in the spring and eleven hours in the fall.
Arizona and Indiana
If you live in an area that does not recognize DST you must press the (unmarked) DST button for one second to deactivate your clock's DST
program. To reactivate the DST program simply press the DST button again for one second.
If you cant rectify the probelem, contact
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
or enter their website at
The device is a repairable one. OK.
Posted on Mar 14, 2011
I replaced the battery in my clock the hands go to 12 then stop there. How do I fix?
check to see that the paper of the clock face has not warped to the point whereas it stops the hands if face of the paper withe the numbers on it is not the problem the you can buy new clock motors at micheals craft store for around 7-8 dollars
Sep 29, 2017 | The Computers & Internet
I need to know how to reset the time on atomic clock HD-1688
Atomic clocks set the time automatically.
Jan 19, 2017 | Home
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
How to set the time on an HD 1688 Quartz wall clock
When you put in a new battery, the hands advance to the hour and stop. It then waits to receive a radio signal and sets the time.
to do a manual set, insert the battery and hold down the M button until the correct time. Don't go past it or you will need to continue until it comes up again. There is no reverse.
The previous answers don't fit the HD-1688 Sheng Bang clock mechanism that I have.
Mar 22, 2012 | Audio Players & Recorders
I have oil in my throtle body 1993 toyota4runner 3.0L What could it be
IF YOU REPLACED THE HEADS WITH REBUILT/NEW HEADS:
A side effect of increasing compression when you bolt on fresh heads, is broken piston rings. It's beneficial to replace the rings & bearings and at least remove the ring ridge at the top of the cylinder wall if not re-bore when replacing heads due to the higher compression that will cause.
If you just put on a set of used heads.
There's also the chance that the new headgaskets didn't seal completely, (usually due to a problem with surface prep or a warped head/block), but if you've got high mileage, it's usually the rings.
A set of rings can be replaced, but you'll want to make sure they haven't cut into the bore so much as to cause blow-by once new rings are installed. Eliminating the ridge by carefully using a ridge reamer at the top of the cylinder to prevent breakage of the top ring from impact.
Hone the cylinder walls gently & reinstall pistons & new rings!
Good luck.
Mar 21, 2012 | 1993 Toyota 4Runner
What all should I replace while replacing the water Pump on my 2000 ford contour
That's a very good question...but I gather that this car has been taken care of and should be in very good shape and with economy the way it is..I see no reason to get a new car...My advice..Just get the water pump replaced and happy motoring....and don't let any mechanic try to sell you something that you don't need...I'm sure that you've heard the expression"If it ain't broke...don't fix it."..I hope this was heplful...PEACE.....
Jan 05, 2012 | 2000 Ford Contour
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    What battery is used for the Sheng Bang HD-1688 clock. It is an unusual size.
    I do have a Clock with a Sheng Bang HD-1688 Clockwork. There is a normal AA 1.5V battery in it.
    Kind regards Marcel van ****
    Jan 31, 2010 | Hammacher Schlemmer Brian The Brain
    28,282 people viewed this question
     Grubhead
    Grubhead
    Marvin
    Marvin
