SOURCE: Tranmission problem on 1999 Dodge Grand Caravan
Dear wramlal
I had the same problem, drove home just like you did, took it to my mechanic and he changed the "speed sensor " problem solved. "
SOURCE: vehicle stalls when put into gear forward or reverse
first try so SPT gas teatment may sure you have a half tank of gas and then put in a little more of gas if this help change the fuel filter also check the vaccum lines and make sure they are all on and in and good conditon and also checkout the intake manifold for leaks
SOURCE: 2OO2 TROOPER HAS NO FORWARD GEARS, BUT HAS REVERSE.
First check you fluid level,if good have it flushed out with new fluid,if this does now work,time for rebuild,unless you know how to adjust the bands.
SOURCE: 2005 chevy silverado 1500, service 4 wheel drive, gears
Sounds like a bent fork in the transfer case. It is a common problem with your truck. The transfer case is a np236. If it just recently started doing this, the rebuild will cost around $800. If the 4wd has been acting up for a while, the planetary will probably need changed, which is another $200.
SOURCE: after driving for 15 minutes truck stalls,restarts
put a OBD II code reader on it see if it has stored any codes if not replace the TPS sensor and the MAF sensor do the replacements at different times so you don't buy one or the other for nothing
you might want to repost this in the boat section
