M2 consumable reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
THe Maintenance call is not a serious issue, as the machine can continue working without doing anything about it, but if it really bothers you, you must go into the service mode (utility, stop, 0, 0, stop, 0, 1) the go down to clear data-> yes-> total clear-> yes.. It should say total cleared. Turn the machine off and back on, and bob's your uncle. It's basically just a maintenance counters that need to be reset.
