Lexar Flash memory card - 32 GB - Class 4 - SDHC Logo
mee pha Posted on Aug 14, 2012
Memory card error
When i come to use it the card is showing that memory card error
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1503
Points
7
Maybe it needs to be formatted,or sometimes there is a really small slider swith thingy that locks it so it cant be used or erased.
How to correct memory card error
The following video shows troubleshooting steps for memory card error:
Dec 08, 2012 • Cameras
1helpful
Camera says memory is full
Sometimes due to virus attach or some unwanted files memory card shows such type of errors even there is memory space in it. IN this case just format your memory card with the help of a computer device. After formatting your memory card will not show such type of errors again.
3helpful
Why does it say memory card error on the screen
Hi there, For few reason camera showing memory card error.
1. Memory card damaged.
2. your memory card finished is life time storage memory.
3 . virus infected.
4. If your memory card storage capacity more than camera support card then its also show to you. For example your camera support maximum 2 GB card, but your try to use more than 2 GB memory card.
I suggest your remove the memory card and scan by updated antivirus. After that, if not working then fomat it and try.
Thanks & waiting for your feedback.
3helpful
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
3helpful
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Memory card error
Connect your memory card to a computer by using a card reader. Format the memory card in your computer treating it as a hard drive. Good luck!
2answers
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Top Lexar Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
August Brown
August Brown
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
