Question about Bunn BTX-B ThermoFresh 10-Cup Home Thermal Carafe Coffee Brewer, Black
My Bunn BTX-B coffee maker won't heat the water anymore. I do not hear the water heating either? I have tried emptying the water and staeting over but the heater is not coming on. Is this fixable
Date of purchase is 08/23/09 and I am mad I only got three years out off a very expensive coffeepot! Is there anything I can do to fix it?
    New Friend:
  • 5 Answers
The Bun BTX-B has a pair of thermal fuses located on top of the water heater storage unit. If the pot is left without use for a week or so, the thermal fuses will blow if the top of the tank gets too hot (about 150 degrees Fahrenheit) due to the evaporation of water in the storage tank. The operating directions state clearly that if the unit is not going to be used for a few days to turn off the pot. These are there to prevent a fire in case someone does not follow the direction. This is the "MOST" common form of electrical failure in these pots.
To access the thermal fuse
1. Unplug the pot and drain pot by inverting the pot in an empty sink.
2. Remove the two Phillips screws located under the water fill flipper door.
3. Gently insert a small flat blade screw driver into the front top of the lid and remove top cover.
4. Remove the 4 screws inside the water routing tank and remove routing tank simply by lifting off.
5. The thermal fuse is mounted to the top of the tank under a clip and is easily slid out from under the clip. There is a brown wire (goes to power cord neutral) and a black wire (goes into tank disk access hole). Simply measure with a multimeter at lowest ohm setting, the meter should read continuity between the black and brown wires, if it reads an open circuit, the part is bad.
A replacement thermal fuze assembly kit is available off e-bay for about $10. You can buy individual thermal fuzes and replace one of the two that is bad for about $3, but I recommend the kit for most consumers as it comes with wire crimps already mounted and far easier for the average person to simply install. Repair takes about 5-10 minutes.
Posted on Jul 24, 2015
    New Friend:
I just had the same thing happen. After 3 years the unit will just not heat up water. I am not too adept at replacing things so taking the unit apart would not be something I would like to try. I would appreciate other options. Getting a reduced rate replacement might be the best. Thanks for your feedback.
Posted on Nov 24, 2012
SOURCE:
  • 125 Answers
SOURCE: Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
Posted on Mar 23, 2009
  • 131 Answers
SOURCE: bunn commercial coffee maker plug overheats, no hot water
Most likely this is your heating element, but it could also be your main thermostat
Posted on Feb 13, 2009
  • 41 Answers
SOURCE: Bunn VP-17 Coffee Maker
I would suggest descaling the unit, or replacing your thermostat.
A defective thermostat would not cut out the heater after the water is boiled, excessive scale would render the thermostat ineffective, but not to the extent you describe.
Hope this helps.
Posted on Oct 15, 2008
SOURCE: water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
Bunn coffepot will not heat or turn on.
after nearly 8 years of service a water leak shorted the heating element and the short caused a small metal thermal fuse to open
Sep 20, 2017 | Coffee Makers & Espresso Machines
My phone's (LG PRIME) touch screen isn't working.
No. I had a similar problem. Have to have it sent off to be fixed.
May 07, 2011 | LG Cell Phones
If the coffeepot stops working after a year do you have to send it back to company or can you take it back where you purchased it. I have the DCC-1200
you probably want to send it to the company because usually a store only has a 30 day return policy try to send it back and see if they can fix it
Feb 28, 2011 | Cuisinart DCC-1200 Coffee Maker
Coffeemaker is falling apart
Unless the product is still under warranty, I would look for a new different brand. I have personally used a 'Mr Coffee' unit with similar features and with the exception of periodic cleaning with water/white vinegar solution, it has worked fairly well. The pot dribbles a little if not carefully poured and if the basket is not fully seated, coffee runs all over. Everyone has had a turn at dealing with poorly made/designed products that fail to meet expectations. Better luck next time!
Mar 01, 2010 | Braun KF 590 10-Cup Coffee Maker
My hard disc purchase date is march, 2006, It is not working can I replace it
Most drives are under warranty for three years from purchase date.
You can check to see if it's under warranty from Hitachi HERE.
Nov 24, 2009 | Hitachi Deskstar® 7K80 80 GB SATA Hard...
Xp does not see as a re-writeable drive
Wow two burners hooked up I wonder why there is confusion here. I would recommend you taking out one of those burners to save issues like this something is geting fouled up and verry confused here. Your runnig two burners and who knows why but anyhow to get rid of this issue take out a bruner.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Mad Dog Multimedia (md-52xcdr) CD-RW...
Need to Add Dates in Excel
Here is one way I just tried:
Say the date purchased is in A1.
You want the Est Life in A2.
In A2 type: =A1+(3*365)
That will add 3 years.
For 5 years: =A1+(5*365)
Try it out!
Note: You will need to format the cells to Custom>mm/dd/yyyy
Nov 21, 2008 | Microsoft Excel for PC
TV Problem
SANYO MIGHT HELP YOU BUT YOU NEED TO CALL IMMEDIATELY BEFORE MORE DAYS GO ON..
Feb 21, 2008 | Televison & Video
Zenith plasma
dont get mad like i did, report this problem to zenith, they seem to be aware of the problem with this particular model.
i gave them the model number and they requested the purchase date, then extended the warranty and gave a number for a local repair shop which came for my set a couple days ago.
so far so good. it may be a while until i know whether the repairs will work, however hats off to zenith, so far, which seems to be providing appropriate customer service and standing by their expensive products.
Jan 14, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Mr Coffee
If your coffee maker is under a year old, take it to a authorized service center for free repair or replacement.If its over a year then the complete heating element assembly must be replaced.However, this part is only available to authorized service centers and is not sold to consumers.
Nov 04, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
8,464 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
