VP-D351 need to connect with TV. What type of cable is required
Samsung VP-D351 pal, I m having the cable that I connect to TV with camera , but i cant see anything on TV.
Can anybody help to get the cable required.
Re: VP-D351 need to connect with TV. What type of cable...
Make sure your TV is a PAL unit. The easiest place would be to look in the owners manual. If you no longer have it, there should be a PDF format online. It should tell you what cable you need.
Have you installed samsung VP-D351 driver in your computer? If the driver already been installed, it may crashed and need new installation. If you had not istalled it before, you have to install it before pairing them. The CD driver usually bundled in new VP-D351 package together with owner manual and service centre address.
You need a USB cable to connect this camera to your computer, to get the proper USB cable for it you can go to a new computer or electronic store near your place and take the camera with you and they can provide you the needed USB cable for it.
This is the type of cable that you will need. The connector should be towards the front of the camcorder on the side that the tape goes in (if I remember correctly). The connector you are looking for is hidden under a cover. Hope this has helped you. www.austintelstarservices.com
i had same problem, solved it with replacing the lcd fpc lead (ribbon).this is the lead to the screen.it breaks after about three years.this is a common fault.. replacement part from Partmaster.co.uk or 0870 240 6603..part number..SAMAD9706489A. cost £11.40.. its easy to replace ..takes a little time.. i have emailed instructions to two others and they have sucessfully completer the task.. if i can help with instructions,please ask.. i have also purchaced a second ribbon for next time..(3 years time )..good luck stefan.
If you are running windows vista this will be the problem.There are no drivers for vista firewire..If other windows then try samsung support for required driver.
you have 2 differnet problems. white screen is a bad ribbon cable inside unit.. eject r is a bad tape transport. something broke inside or the tape transport is outta alignment.
