Chase TX TechnoLuxury - 800 Series: Linear Chronograph - T3C310 Watch Logo
Yaqoob Ishaq Posted on Nov 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My watch will work as a stopwatch but the time will not progress and I am not sure if it a battery or mechanism issue
I can set the time, but once the crown is closed it will not progress. The second hand remains static. It has moved a couple of times, advancing the time by 5 minutes or so but then stops again. The stopwatch function works fine which leads me to think that if there is enough battery life to do this then why will the time not work?
Brian Williams
Level 2:
Sergeant:
  • Expert 217 Answers
  • Posted on Nov 10, 2017
Brian Williams
Expert
Level 2:
Sergeant:
Answers
217
Questions
7
Helped
59021
Points
696
Yes it is not a battery problem , you say the second hand remains static therefore I presume the other hand is moving ? if this is the case it might be because the second hand is not attached to the shaft properly although you say you can set the time and it will work for a short period and then fail it still might be the case which is a fairly simple job , hopefully it is not in the watch mechanism that causes it to not work .
1 Related Answer
Anonymous
  • 1970 Answers
  • Posted on Jul 10, 2010
SOURCE: My watch stops 1-2 minutes after setting it
mcdevito75 here, Sounds like your Rolex needs a reular serviceing, Check with the Repair Service Directory here at fixya, bottom of this page click on Reapir Service Directory, then watches, choose a repair service that specializes in Rolex watches.
My Invicta reserve speedway won't keep time but the stop watch works need help
If the stopwatch is working but the timekeeping is not accurate on your Invicta Reserve Speedway watch, there could be several possible causes for the issue. Here are some steps you can take to troubleshoot the problem:
  1. Check the battery: A weak or dying battery can cause timekeeping issues. Try replacing the battery with a fresh one to see if it helps.
  2. Check the movement: If the battery replacement doesn't solve the issue, the movement (the internal mechanism that powers the watch) may be damaged or worn out. A professional watchmaker can diagnose the problem and repair or replace the movement if necessary.
  3. Check the setting: Make sure the watch is set to the correct time and time zone. You can refer to the manual or instructions for your watch on how to set the time and time zone.
  4. Magnetization: Sometimes, exposure to magnetic fields can interfere with the timekeeping of a watch. If you suspect that your watch has been exposed to a strong magnetic field, take it to a professional watchmaker for demagnetization.
  5. Water damage: If your watch has been exposed to water or moisture, it can cause damage to the movement and affect the timekeeping. You can try drying out the watch and replacing the battery, but it may require professional repair.
If none of these steps resolve the issue, you may need to take your Invicta Reserve Speedway watch to a professional watchmaker for diagnosis and repair.
9answers
No watch instructions
- CHARACTERISTICS
1. Stopwatch: Measures up to 9 hours, 59 minutes,
59 seconds and 99 with 1 ¤ 100 second readout.
• Lap time measurement: Up to 9 lap times
can be measured. The lap time difference and
the fastest lap time are calculated and displayed
during the measurement.
2. Time/calendar display: Hour, minutes, seconds,
month, date and day of the week.
• Automatic calendar adjustment: Calendar
adjusts automatically for odd and even months
including February of leap years, but not for
February of common years.
• Time indication: Changeover between 12-
and 24-hour indications is possible.
3. Daily alarm: The alarm can be set to ring on a
24-hour basis.
4. Dual time: Time of a different time zone can be
set and displayed.
5. Stroke function: The watch can be set to beep
at a selected rate to serve as a pacemaker in
jogging, etc.
6. Countdown timer: Up to 9 hours 59 minutes
and 59 seconds can be set in seconds.
• “Lap time” refers to an elapsed time required to
cover a given section of the whole distance.
1. At the start of the activity, depress button “D” to
start the stopwatch.
2. At the end of the first lap, depress button “A”.
The first lap time and lap number are displayed,
though the second lap time is being measured
internally.
3. Depress button “A” to release the lap time before
the end of the second lap. The first lap time and
lap number disappear, and the measurement in
progress and “0” are displayed in place of the lap
time and lap number, respectively.
4. At the end of the second lap, depress button “A”.
The second lap time and lap number are displayed,
though the third lap time is being measured
internally.
5. Measurement and release of the lap time can be
repeated by depressing button “A”.
6. At the end of the activity, follow either of the two
methods below.
a. To display the final lap time, depress button
“A”. Then, depress button “A” to release the
lap time, and depress button “D” to stop the
measurement.
* The time displayed when button “D” is depressed
is not the total elapsed time of the
activity, that is, the time that elapsed from
the start until the end of the activity but the
time that elapsed from the start until the
stop of the measurement.
b. To display the total elapsed time of the activity,
depress button “D” to stop the measurement.
7. Depress button “B” to reset the stopwatch.
Stopwatch operation
Depress button “C” to show the stopwatch display.
Start Stop Restart Stop Reset
Accumulate repeatedly by
depressing button “D”.
Accumulated elapsed time measurement
D D D D B
Notes:
1. When a lap time measured is the fastest among
the lap times previously measured, a short beep
rings to signal that the memory has been updated
with the new fastest lap time.
2. The lap number counts up to “9”. After “9”, the
number returns to “1”.
• While a lap time is being displayed, depress button
“B”. With each depression of the button, the
difference between the displayed lap time and the
previous lap time is displayed in the following
order.
Latest lap time ® Lap time difference
Fastest lap time ¬
The selection of the display can be made in the
following order with each depression of button “C”.
* A flashing display mark indicates that the corresponding
function is in use.
- HOW TO USE THE STOPWATCH
• The stopwatch can measure up to 9 hours, 59
minutes, 59 seconds and 99 in 1¤ 100 seconds.
* Even if the stopwatch display is changed to another
while the measurement is in progress, it continues
counting properly. After the stopwatch is used,
however, be sure to reset it as the battery energy
is consumed enormously to shorten the battery
life.
Stopwatch display mark
Stopwatch operation
internally.
internally.
methods below.
measurement.
Notes:
Lap time difference and the fastest lap time
order.
• The lap time difference is displayed without a plus
or minus sign. Instead, the lap number of the
faster lap time is always displayed at the right of
the “–” mark.
Ex.)
Notes: 1. While the measurement in progress is shown
on the display, the lap time difference
and the fastest lap time cannot be shown
by depressing button“B”.
2. While the latest lap time, lap time difference
or the fastest lap time is shown on
the display, the display cannot be changed
to another by depressing button “C”.
* With each depression of button “A”, month and day
are displayed alternately.
* With each depression of button “D”, the display
changes over between the 12- and 24-hour indications.
1. Depress button “C” to show the time/calendar
display.
2. Depress button “B” to show the time/calendar
setting display. The second digits start flashing.
3. Selection of the digits to be adjusted (flashing)
is made in the following order by depressing
button “D”.
4. Depress button “A” to set the flashing digits.
One digit is advanced with each depression of
button “A”. Digits except seconds move quickly
by keeping button “A” depressed.
5. After all the adjustments are completed, depress
button “C” to return to the time/calendar display.
Seconds setting
When the seconds digits are flashing, depress button
“A” in accordance with a time signal. The seconds
are reset to “00” and start immediately.
Note: When setting the hour digits in the 12-hour
indication, check that AM/PM is properly
set. Only “PM” is displayed and there is no
indication for the AM setting. In the 24-
hour indication, there is no indication.
My watch not working how to setup
  1. Check the battery: Before attempting to set up your watch, make sure that the battery has not run down. If the battery is dead, you will need to have it replaced by a professional watchmaker or authorized Breitling service center.
  2. Wind the watch: If the battery is not dead, you may need to wind the watch to get it started. Most Breitling watches have a self-winding mechanism, but if it has not been worn for a long time, it may need to be manually wound.
  3. Set the time: Once the watch is running, you can set the time by pulling out the crown (the knob on the side of the watch) and turning it until the hands are set to the correct time. Push the crown back in when the time is set.
  4. Set the date: If your watch has a date function, you can set the date by pulling the crown out to the second position and turning it until the date changes. Push the crown back in when the date is set.
  5. Synchronize the time: If your watch has a chronograph function (stopwatch), you may need to synchronize the time to ensure that it is accurate. You can do this by starting the chronograph and waiting for it to complete a full revolution.
Feb 12, 2023 • Watches
My casio 5177 558d stop watch second hand is not working from one week.before a week its work works properly.time is correct and date is ok.what is cause of it that stopwatch second hand is just move on it...
It sounds like there may be an issue with the movement of the second hand on your stopwatch. There are a few possible causes for this problem. One possibility is that the battery in your stopwatch may be running low and needs to be replaced. Another possibility is that there may be a problem with the mechanical movement of the stopwatch. This could be due to a loose or broken part, or it could be a result of wear and tear over time.
To troubleshoot the issue, you could try replacing the battery in the stopwatch to see if that resolves the problem. If the problem persists, you may need to have the stopwatch serviced by a professional watch repair technician. They will be able to diagnose the problem and repair or replace any faulty parts.
2answers
2helpful
How to stop stopwatch on revo rv1006 watch changed the battery but need to stop the stopwatch
Push the upper button once. The stopwatch hand will freeze. Push the bottom button. Stopwatch hand should move to ZERO position. Rate me, please.
Jun 24, 2010 • Watches
Hello
This is not common to have two different movements in one watch ( mechanical and electronic).
I'm pretty sure that the analog part is battery driven, so, no need to wind it. You may have the watch with two separate batteries, each one feeding its own movement. Check if you have this version and replace the analog watch battery.
If there is only one battery in watch, then the analog part is faulty or the battery is underpowered.
In this case you will need the help of the watchmaker.
Do not forget to rate, please.
Jan 30, 2009 • Watches
15helpful
3answers
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
18helpful
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
Top Chase Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Chase Watch Expert? Answer questions, earn points and help others
