Question about Patton PUH9000-U Heater
Space heater will power up, but not start,
This patton space heater is relatively new, within a year and hardly used. The on indicator light will go on, but the fan and heat will not. now I know this isn't the best solution, but sometimes it will work after we shake it a bit, almost like something is loose or stuck. thanks so much for any help!
  • stockcarnut Mar 23, 2008
    same problem as listed,unit is new and will not turn on unless you shake it,then runs for less than 1 minute and shuts off!!
  • Anonymous Jan 17, 2009
    haha, i just tried shaking it and it works...who even thought of the genius idea to shake it?
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Posted on Mar 01, 2009
SOURCE:
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Patton space heater power knob isn't working
First thing check see if you have power going to switch with a multimeter if you have one if there's power going in it switch need new switch probly you can us your multimeter to test switch on ohms
Mar 01, 2013 | Heating & Cooling
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
My Patton PUH682 utility heater from 2011 is otherwise in excellent condition but Auto Safety Shut-Off seems to be a design problem. My overheat sensor quickly shut off the unit when surrounding air was cool. It is inside the bottom of the fan box wired between the on/off potentiometer and heating coils.
I identified it by turning on the heater and watched the metal contacts separate as it tripped. On my unit, the defective overheat sensor is hardwired. Since it was otherwise useless as a heater, I decided to jerry-rig it and hope for the best. I pried back the sheet metal edge of the fan box and wrapped the sensor with electrical tape. Then I took a very small squeezable metal paper clip and lined it with electrical tape. I clamped it over the overheat sensor and it fits perfectly to prevent the metal plates from separating. Now the heater works the way it should. The cable, coils and plug don't overheat on Hot setting and it runs continuously.
Jan 11, 2011 | Patton PUH9000-U Heater
Patton MH761 coil wire can these be replaced? The wire only heat about an 1/8 of the total length and does not produce much heat. I asked about it at the local hardware store and they indicated that the...
Nickel Chrome hard wire in coils for heater element are not worth stocking as new complete heaters are very inexpensive and as a qualified electrician must fit it, to replace the heater element is not cost effective.
Jul 15, 2017 | Patton MH761 Utility Heater
My Patton PUH680 space heater is not working. Do you offer replacement coils?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Nov 12, 2007 | Patton PUH680-U Utility Heater
Heating & Cooling Logo
828 people viewed this question
Top Patton Heating & Cooling Experts
Audrey Messer
Audrey Messer
Paul Carew
Marvin
Marvin
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
