Water is coming from evaporator drain pan most likely. lots of humidity right now and 1st thing your ac is going to do is remove this from air. most likely cause would be condensation line clogged or if you have condensate pump, then it also could be cause. to remove cover usually you have to remove air filters look for any screws and possibly front louvers pull down. this usually does not give you access to drain pan. unit usually needs to be removed from wall plate and this might involve refrigerant lines being removed, and for that my friend you defiantly want a qualified professional.
SOURCE: BROKEN/MISSING HITACHI AIRCONDITIONER REMOTE CONTROL rar-2p2
abhay .hi their is a problem in my remote
SOURCE: Hitachi RAS-10C2M. What size of air conditioner
If the number you say is the model number, it appears to be a 10,000 BTU.Check on the sides of the unit, or inside where the air comes out, and it should give the numbers.It should say 5000 to1800 BTU, if it is a 110 volt unit. BTU is what you are looking for if you want the output, not HP.
SOURCE: I NEED A USER MANUAL FOR A HITACHI SPLIT SYSTEM
http://www.hitachiaircon.com/argws/listDOCS.do?pageName=Technical+Manuals&range_id=1&page=PAGE&button=Submit&categoryID=-1&action=getListTechManuals&d-49653-p=14
SOURCE: Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
