I have cleaned it, changed the needle, rethreaded it, turned off for a long period and on and the message won't go away.
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again.
Keeping my fingers crossed.
Pfaff expression 4.0 after cleaning out the thread jam, click the OK or chekmark button on the front of the machine. per the reference in the manual
SOURCE: stitches not even
the needle bar on my sewing machine is loose not sure how to adjust will not go through the fabric to grab the bobbin thread
please help
SOURCE: hobbylock 794
You have a timing problem which needs a technician to repair. to do this properly, you need some special gauges which, generally , are not found just anywhere. Take it a technician and get an estimate before you leave it.
sewman7
SOURCE: Pfaff 2048
The timing has been knocked off when it jammed. The only way to
correct this is to take it to a shop and have it retimed. This is common on these machines.
I have 25 years working on Pfaffs
SOURCE: pfaff 786 cannot get the second needle to form a stitch
Sorry to say I had the same prob and finally gave up on using 2 needles and 4 threads. Other than that I love the machine but will be replacing it soon due to inability to find replacement parts as it is sooo old. :(
