I lived to bury my desires and see my dreams corrode with rust. Now all that's left are fruitless fires that burn my empty heart to dust. Struck by the storms of cruel fate, my summer mcrown i9s sere. Alone and sad, I wonder if the end is near.
Contributor
Posted on Aug 15, 2012
Re: looking for poet's name via a few lines known by...
Tips for a great answer:
- Answer the question.
Tell us some more! Your answer needs to include more details to help people.
You can't post answers that contain an email address.
Please enter a valid email address.
The email address entered is already associated to an account.Login to post
Please use English characters only.
How do i get rid of the horizontal line going through the TV
Could be your display panel. check all your connections between the T-con & display panel, look specifically for corroded contacts at the panel plug, if you have that, try to clean those contacts.
If that doesn't cure it you may need the display panel. This would not be cost effective unless you found a used unit with a known good panel & could purchase very inexpensively.
Known Mintek DVD Code Hacks
window.google_render_ad();
Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
Press SETUP
Go to "Preferences"
Press 255 135 (or 225422)
Press LEFT and DOWN quickly
Current RC should be displayed
Press the button for the desired RC (0 = codefree)
Press SETUP
Mintek MDP-1060
Press SETUP
Go to "Preferences"
Press 253 135
Press LEFT, DOWN, ENTER, SETUP quickly
Press ENTER, SETUP
Mintek MDP-1720
Press SETUP
Go to "Preferences"
Press 215 345 (or 251251)
Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
Press SETUP
Go to "Preferences"
Press 251 131
Press SETUP
Mintek MDP-1750 / MDP-1810
Press SETUP
Go to "Preferences"
Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
Press SETUP
Mintek MPD-1760 / MDP-1815
Press SETUP
Go to "Preferences"
Press 224 455
Press SETUP
Mintek MDP-5860 / MDP-5861
Press SETUP
Go to "Preferences"
Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
Press SETUP
Mintek MP 1710
Open & close the disc tray
Push SETUP on the remote control
Push 1, 3, 6, 9
Push the left menu arrow button 3 times -- NOT the |<< or << button
Push the right menu arrow button 1 time -- NOT the >>| or >> button
If you see a new menu item named "VERSION", enter that menu
Change "REGION CODE" to 0
Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350
no known hacks
Words u can make with only using these letters m,p,u,o,t,e,r,s,c
Computers Spectrum Computer Crumpets Computes Customer Costumer Posture Rectums Copters Pouters Costume Troupes Crumpet Recoups Compute Tumors Pouter Truces Tropes Poseur Uprose Troupe Trumps Presto Septum Cruets Escort Croups Sprout Eructs Mouser Mopers Muster Courts Copter Course Stupor Coupes Poster Sector Tempos Metros Ouster Custom Erupts Routes Tromps Corpse Corset Corpus Spruce Source Recoup Rectos Comets Purest Comers Court Croup Strop Strum Curst Crept Trues Cures Strep Ecrus Puces Upset Mutes Rotes Proms Copes Stomp Outre Store Corps Estop Coupe Mores Trope Crust Mopes Tomes Moper Pores Smote Setup Coups Serum Prose Temps Spore Pesto Cruet Tumor Scout Crops Score Scope Topes Cotes Outer Spume Super Rumps Mouse Moues Stoup Erupt Routs Cruse Route Eruct Roust Rouse Roues Storm Copse Scour Ports Curse Tempo Ropes Cuter Romps Trump Comps Pouts Sport Truce Comes Comer Perms Pours Tromp Tours Recto Corms Spurt Stump Comet Terms Motes Cores Poets Purse Poems Metro Poser Crest Spout Euros Muter Coup Cope Suet Comp Toms Step Pout Sump Pour Pots Cops Pure Most Ruts Cups Sect Cute Umps Port Puts Pore Cots Poet User Recs Pets Rout Sumo Pest Peso Pert Come Perm Rote Outs Spec Rust Sour Soup More Prom Core Rues Ores Rest Tome Opus Opts Euro Tope Opes Pose Romp Roes Cure Stop Ruse Mute Rope Must Muse Post True Corm Crop Cuts Sort Toes Moue Mots Mote Rots Stem Cues Cote Mops Tour Some Tore Mope Spot Rose Temp Tors Rems Pros Ecru Oust Poem Sure Tops Erst Emus Curt Spur Ours Term Cost Puce Curs Cusp Reps Rums Roue Sore Sou Emu Oms Eco Per Rue Pet Roe Pro Cup Sec Sot Cue Ope Sop Met Ems Tor Opt Mus Set Top Mrs Sue Pot Tom Rum Toe Ups Mot Use Put Pus Rut Rec Cot Cut Sup Rem Cos Sum Rep Ops Out Mop Res Cur Our Ort Ump Ore Cop Rot To Or Ms So Em Op Us Om Mr Re Up Mu Me Um
What are some words you can make out of the word experimentation
trot trip trio trim tree trap tram tote tort torn tore tope tone tome tiro tire tipi tint tine time tier text tern term tent temp teen teem teat tear team taxi tart tarp taro tarn tare tape tamp tame rote rope romp roan roam rite ripe riot rime rent rein reap rate rapt rant rani ramp rain prom prim pram port pore pone poet poem pita pint pine pier pert perm peon pent peer peen peat pear pate part pare pant pane pair pain oxen open omit omen note norm nope none nite nine next nett neon neat near neap nape name mote morn more mope moat moan mixt mitt mite mire minx mint mini mine mien mete mere meet meat mean maxi matt mate mart mare mane main item iron iran iota into expo exit exam epee emit emir earn axon atop atom apex anti ante anon amir amen aeon
Left turn indicator intermittent how to fix?
The turn signal indicator switch could be corroding (getting rusted on the inside). You could take it out & break the corrosion/rust & lubricate it with wd40 & put it back in..hopefully it solves the issue. If not, then you might need to get another indicator switch. You start off by taking off the steering wheel neck panels
I can't 'text' because IT isn't working-HELP!!
no PC stated full model number
no OS stated. XP?
ASAP only works for paid service, this is free advice. not paid.
so no ASAP.
we are not HP either why not ask on their forum>?
never post emails. unless endless SPAM for 100 years is fun?
my wild guess.
OLD PC
running XP
and infected,
right?
Is it expensive to replace the fuel pump
Look up the cost of a fuel pump on the internet Rock Auto.Com -- has brand name parts & better prices than your local parts store If you don't install yourself, you have to add a few hours of labor. The pump is about $50 to $60.00 The entire assy with tubing,if that is rusted away, is about $170.00 Other than draining & dropping the fuel tank,it is any easy job
