Question about Dell Inspiron 9100 Notebook
Laptop screen has horizontal white lines running across half the screen
My laptop computer screen has horizontal white lines running across and there is sort of a flickering action at the very top of the screen. Thought it was a virus because when the problem first began, I would run different virus software and the screen would clear up. But now, that does not work and the flickering white lines are still on the screen. Please help!!!!
  • tedoctrine Sep 14, 2008
    I hav a sony vio PCG-K37 I have a white line about 1/5th from the top of screen that will not leave on black screen as well changed resolution of screen and it is still there. Terry
  • Valeriy Bacherikov Feb 09, 2018
    It may be bad contact in the monitor connectors with motherboard. Maybe you drop your computer or just because of water in it or humidity.
    New Friend:
Horizontal lines on bottom third of my Toshiba (Satellite Pro) Laptop with XP windows got fixed by flicking my finger on the laptop screen! Was it a loose connection? I don't know. Change of screen resolution did not help, Rebooting, did not help nor restoring to prior dates. Thank you guys.
Posted on Dec 23, 2010
  • 2 more comments
  • nedselvog Jan 12, 2012
    Hilarious. This actually worked. Thanks for the super-simple solution...
  • christydull
    christydull Apr 03, 2012
    i did that for about a month. then it started getting worse. sometimes have to squeeze screen. bounce laptop on lap. or log off then back on. like i said, tapping back of laptop screen worked for a few months then decided it wouldn't. trying to find solution. changed resolutions, checked drivers, etc. nothing
  • darlavon01
    darlavon01 Dec 10, 2012
    what was the solution?
  • darlavon01
  • 3 Answers
Ive encountered laptop screens that are bad, with broken connections or a small carack on the very edge of the screen. I have an old laptop with the very bottom line of pixels dead. But as i push on the edge of the screen they flicker. Try carefully squeezing around the edge of your laptop screen near the lines. Its possible the screen itself is defective and need replacing.
Posted on Dec 23, 2007
    New Friend:
I have horizontal lines everywere on my laptop it stops me from doing stuff like internet and everything i rlly need help is it VIRUS what should i DO ??? my laptop is like 1 year i bearly use it ,,,,,,,,,,,,,,,,,if i have to change the screen that will cost me 500$$ whats the PROBLEM here
Posted on Jan 05, 2010
I have the same problem of horizontal white lines running across the bottom half of the screen. This has got progressively worse over the last three weeks. I have sent the laptop to HP under the one year warranty and they have advised that I must have damaged the screen because it is cracked, and it is therefore not covered by the warranty. The unit has not been dropped and the problem occured when using it normally. So any ideas what has caused this?
Posted on Jul 08, 2009
  • RATTIKLE COMPUTERS
    RATTIKLE COMPUTERS Mar 02, 2013
    lifting it from the same corner all the time always lift from the center and slowly
  • 64 Answers
Have you tried changing display options? Right click anywhere on the desktop, choose Properties and then the Settings tab. Try 800 x 600 for a big resolution and then go smaller from there. Also from the same Settings tab click the Advanced button and try different refresh rates. It sounds like a hardware problem but the connection to the possible virus is interesting. You might also check for new video drivers on the manufacturer's website. AVG has a great free anti-virus that I use on all my systems, a 2nd opinion never hurts!
Posted on Mar 28, 2007
  • 100 Answers
Try plugging an external monitor and toggle the screen with ALT+F5. Any software problem or virus should be reproduced in the new screen.
If the image is good in the external monitor you probably have a problem in the LCD screen or cabling. You can get a replacement screen here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
Posted on May 23, 2008
    New Friend:
I have the same Horizontal line, about 3 inches from the bottom of my LCD. I tried pressing the edge of the line and it flickered, pressed all edges including the bottom of the LCD and the line dissappeared. Thanks for all your suggestions.
Posted on Jun 21, 2011
  • Tony Curry Nov 08, 2011
    I have a Toshiba Satellite which had horizontal lines on the bottom half of the screen. I took the advice about pressing the edges and it worked. I was about to but another screen which cost $100. Thanks for the advice. Saved me 100 bucks.
  • Anonymous Aug 29, 2019
    bad LCD, and the other guy here answers 11 year later. wow.
  • 255 Answers
On a lot of these LCDs, the connection to the screen itself from the harness is the culprit. If the screen is cracked, there is no saving it, not even by talented MacGyver types. But if you notice that when you disconnect this harness and reconnect it and the screen works (remember - power down, piddle, assemble, then power up), probably the best thing is to use some contact grease on these connectors. This grease keeps oxidation from occuring by an electrolysis reaction from two slightly dissimilar metals and by just atmospheric moisture. IMPORTANT: Use only a smathering of the stuff on both the contacts and the contactees. That is, get your fingertip damp with the stuff and rub some on the contacts. It doesn't take much. Contact is made in an atmosphere now created by the grease.
This is true for any contact in a computer or notebook on most any part of the circuit that has gang plugs or post plugs. Manufacturers don't usually use this stuff (except maybe on smallish displays like calculator displays that use the little rubber and wire loop blocks to make the connection) because they've found that satisfactory performance is obtained from dry contacts. (It costs them the labor of an additional step to put the grease there, so they would rather not do it.)
You can get this grease at any electronics supply house or your local Radio Shack. (Bonus tip: Works on car batteries too!! Pull terminals all the way off and grease the posts [or contact face for side posts].)
Paul
Posted on Nov 23, 2009
  • tony olney Nov 07, 2011
    I really appreciate this large piece of advice. I haven't tried to do this yet but the way you said it, I am sure it will change the condition of the contact points.
    New Friend:
The same thing is happening to me, but i also have orange vertical lines running through the screen. originally, there was one line total, but now there are 8 in all. ive plugged my laptop (Dell Latitude D820) into my tv and the lines are gone. sometimes the whole screen starts rapidly blinking white. this hs happened when it was plugged into my tv, and the tv screen was normal and i could still control everything normally, all the while the laptop screen was having a laptop seizure.
Posted on Jan 25, 2010
How can i get rid of my horizontal line
Posted on Oct 26, 2008
    New Friend:
I accidentally poured some water on my screen and i started the rubbing thingy with both of my thumbs, i tried harder and harder(really hard) but still its size has only decreased apart from that its the same help pleaseee :'(
Posted on May 25, 2013
There meyby that the screengard is dead
Posted on Jan 17, 2008
    New Friend:
    Problem Solver:
  • 17 Answers
Turn it off and on again, it's because you've left your laptop on for too long
Posted on Jun 06, 2013
SOURCE:
Thin white line across laptop screen
check lcd display data cable if cable is fine problem in display unit
Apr 27, 2014 | Computers & Internet
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
My dell laptop has horizontal lines across the screen
Last one I had with this it was the connection from the compute base to the monitor. difficult to chk and hard to fix yr self. hv it tested. cheers
Aug 04, 2012 | Dell Latitude D520 Notebook
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
LG F700P monitor black out on top half, horizontal white line
Sounds like your monitor or graphics card may be going bad.
Dec 07, 2008 | Computers & Internet
Screen
Problem with motherboard display unit.you need to repair the unit.
May 28, 2008 | Computers & Internet
Line across my laptop screen
The graphics part of the laptop is going out. Recommend just replacing the laptop, it would be cheaper.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 10, 2017 | Computers & Internet
Dell Inspiron 9100 Notebook Logo
55,259 people viewed this question
Ekse
Clive
Clive
Alun Cox
