Replaced back cover but still no signal. works fine on wi-fi though
Hello every one how are you?
i have lill problem about signal, Therefore sometimes signal is getting down & sometimes my smartphone signal working problem!
plz replay me
Dissertation Writing
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
SOURCE: I cannot connect my HTC desire to my wi fi net
Obvious ones?
Check your WiFi modem is not hiding it's SSID?
Cheers.
SOURCE: wi-fi
You probably called their customer support or billing, which know nothing about technical stuff.
Wi-fi is completely independent from the cellular network, so it will not charge you anything. Wi-fi just connects to a wireless router, like the one in your home, if you have one. In other words it connects to the internet via someones home/office internet connection. I have a touch diamond and dont have a data plan, and only use wifi, works great..BUT:
If you do not have a data plan (pay as you go data) with Bell, IMMEDIATELY get a 'data block' on your phone, at first they might say oh it will not let you use some functions, etc, put insist, persist, and use force if neccesary as they dont like giving you a data block..It costs about $50 per mb if you use the pay per use internet! I think that was the 1X, but im not sure, its ridiculously high!
SOURCE: wi-fi
No, wifi is completely seperate from the cellular network. It will not cost you anything, but will depend on whether or not there are wireless routers/networks near you and if they are secured (with a password) or not. Wi-Fi is basically a home/office internet connection, just wireless.
For example, all starbucks has 'wi-fi'.
If you don't have a data plan for your phone, get a data block immediately from Bell. They dont like giving data blocks, and they say some functions wont work but they mean stuff that connects to the internet, which will cost you if you wifi isn't connected since it defaults to the cellular providers internet. It cost be about $12 for less than half a MB of usage. Their rate per MB is more than $50, im not kidding.. just checked my bill. If you just got the phone you can get the charges reversed just say you didn't know it would connect to the cellular web and that it cost so much etc etc. They should be lenient if you just got the phone etc...
SOURCE: The Wi-Fi on my HTC Wildfire isnt working. I tried
i dont know how to set my wifi
i encountered with some option named vpn
virtual private network
help me to make connection by wifi step by step in settings menu please
When on Disk drive mode, you will not be able to use apps on HTC Sensation XL with Beats Audio that access the storage such asCamera.
HTC SyncSelect this option to synchronize contacts, calendar, and other information between your computer and HTC Sensation XL with Beats Audio.USB tetheringWhen you do not have an Internet connection on your computer, you can select this mode to share the mobile data connection of HTC Sensation XL with Beats Audio with your computer.Internet pass-throughIf you don't have a data plan or you don't have access to a Wi-Fi network, you can select this mode to share your computer's Internet connection with HTC Sensation XL with Beats Audio.
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
, My Htc sensation also drops its cell phone signal suddenly, restarting with battery removed helps for few minutes
