I adjust the cables in the part of the motor and the scooter doesnt brake s, when you stop its moves slowly to the front and in steep streets it doesnt brakesI adjust the cables in the part of the motor and the scooter doesnt brake s, when you stop its moves slowly to the front and in steep streets it doesnt brakes
You can't post conmments that contain an email address.
can I ALSO eliminate the brake system by pull the white plug out ? so disconnect the white-yellow cable?can I ALSO eliminate the brake system by pull the white plug out ? so disconnect the white-yellow cable?
If the brake release lever is not working by this I mean the lever will not move the release position, this could be a case of the brake mechanism has seized up due to water or that sand and grit has got in the brake jamming it.
Try a spray of WD40 on the bake lever mechanism and work the lever back and forth. Failing that brake will need to be replaced.
Hi Scott, the brake itself could be failing or the other issue could be the controller itself or simply a bad connection (hopefully), so check the connections from the brake to the controller
Contact a local DME dealer in your area or, on the internet. Give them your serial number for the GOGO to order a new solenoid brake. It is important to have your serial number when ordering to ensure you get the correct part.
hi, it means that the brake is giving the incorrect resistance , this can be because of a faulty micro-switch or simply a bad connection to the controller so worth checking ..
Please note : i offer a free controller and brake testing , you only pay return postage ..
first of all take a look at the microswitch connected to the brake, these can fail, check the connections from the axle to the frame they are a great source of problems...
hi, 9 bleeps on a go go mean a parking brake fault or motor connection problem , now it could just a be case of a poor connecting however go you confirm the exact controller used ?
Check the brake connections and motor cable connections making sure they are clean and tight.
