I was able to turn on the steam mop, but no matter how hard I pumped the handle... no steam. Someone here said to put vinegar into the water bottle. I realized that they were saying particles from the water could have formed and clogged the steam tube. First, make sure your steamer isOFF!! Turn the steamer upside down as though you were putting a new pad on, Use a slender object to clean out the tubing where the steam comes from. Again, I will say... make sure your machine is off before you attempt this.. Otherwise, when you clean out the tubing the object will become a bullet flying thru the air and can hurt you, Hope this works
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
