Hi, Currently i am having problem to boot my HP DL380 G4 Server. All lights are flashing green and fans are spinning. The server was proper shut down before than suddenly unable to boot. Done all basics troubleshooting as stated in HP service maintenance procedure which are : Re-seat all component includes RAM, Processor, HDD, PMP, Power supply, SCSI card but the problem still persist. Anyone facing this problem before?
SOURCE: Proliant DL380 G4 server occasionally rebootes.
Try to update the firmwares. Maybe the threeshould of the fans are incorrect. A new firmware can correct this problem.
Let me know if this post helps
SOURCE: ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Try to look at this Guide & Manual on "HOW TO"
Just let me know..
Hope my initial idea/info helps you..
Thanks,
micro
SOURCE: A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
SOURCE: Hp compaq prolaint dl380 g4
Even with out the display, can you ping it from the network? If not I would power off the server. Unplug the power. Take the cover off the server, reseat the memory. Pullout the both power supplies and reseat them. remove any cards in the server except the disk controller. Reseat all the disk drives, make sure you put them in the same slot you pulled them from, even though it doesnt matter. Plug back in and see if you get a display. You can move the memory around also or take out some. If you are not getting an intermittent beep or a red display on the front panel, your system board may be shot.
Any indicator (warning) lights triggered?
