1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
this worked for me but i needed to turn it off when i tried it again it dint work help me plz!!!!!!this worked for me but i needed to turn it off when i tried it again it dint work help me plz!!!!!!
You can't post conmments that contain an email address.
Your charging port is probably bad. It is a common issue. You can take it into an electronics shop and they could fix it by sending it to the manufacturer, but it might cost more than a new phone like the HTC incredible
Is the battery charged? Is the charging LED showing up as normal when you connect the charger? Try charging the battery for a few hours and then try to reset the device?
well either the connection with the screen to the phone is messed up or you phone needs to be reset. Try turning it off and back on. or put it on the charger. or go to tmobile and ask them
if none of these suggestions work your phone is defective...hold the power button longer to turn it on. if not that your battery is dead. if your phone isnt charging up, your battery charger is defective. if you know someone with a usb charger, you can try theirs
your phone's charger may be broken. the red light also indicates a dead battery or needs charge immediately. try using another usb charger to see if it works.
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
well plug the charger into the phone with the battery still intact.....then remove the battery while the phone is still plugged in. then unplug the charger and plug it back in........place battery back into phone and then power it up. That worked for me.
take the batteries out and put it back in again and try charging
check in diff power sockets
press the end of the charging cables with little amount of pressure and have a check
try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty
if still did not work then it will be firmware problem with of phone
