Cars & Trucks Logo
susan taylor Posted on Aug 11, 2012
Monte carlo 2001 windshield wipers stopped working
Ss monte carlo 2001 wipers stopped working
Michael Flood
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 28 Answers
  • Posted on Nov 14, 2014
Michael Flood
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
28
Questions
0
Helped
8084
Points
30
Sounds like u need a new wiper motor
5 Related Answers
rockys performance motors
  • 303 Answers
  • Posted on Nov 23, 2008
SOURCE: 2001 monte carlo
do you have spark if you have no spark the crank sensor is bad.do you have fuel presure now. if not check the fuses. nead more info
wickedsteele
AJ Dungan
  • 56 Answers
  • Posted on Aug 09, 2008
SOURCE: windshield wipers
You will need to replace the wiper motor. Most likely the circuit board is bad. You might check with your local chevy dealer and see if there is a recall on the wiper motor before you buy a new one, even if you are not the original owner the car the recall will still be done free of charge. Some chevy models did have a wiper recall. I hope this helps.
  • 303 Answers
SOURCE: monte carlo 2001 ss 3.8 V6
is the battery good if it is shorted out it will do this or if the charging system is not working
ginko
Ginko
  • 19396 Answers
  • Posted on Feb 27, 2009
SOURCE: 2002 monte carlo ss
The fuel filter is located in the pressure line that runs from the fuel tank to the engine, near to the fuel tank.
Keep the engine off for few hours before replacing the filter, to get rid of some pressure in the lines.
Anonymous
  • 213 Answers
  • Posted on Feb 07, 2011
SOURCE: Windshield wipers are not working on a 2002 chevy
there is a clip type on the end of a rod just under the wiper
unplug the cover on the wiper where it is fitted with the body you will find a nut unscrew it and pull out the wiper
open the engine hood and see if you can find the way to reach the point where the wiper nut you opened
run the wiper you will be able to see if the rods are moving if they are moveing you will find whats wronge with it
Broken Windshield wipers
Probably bad end on linkage. Remove wiper blades, then cowl covers, then unbolt entire linkage from motor and cowl to remove it. Inspect and repair or replace.
How do i determin if it is the windshield seal or the cowl drain flooding the passager compartment on a2003 monte carlo ss
Under the wiper panel at the windshield there is aplug on the passenger side that falls out for some reason. also there is a plastic screw that holds the wiper panel down. Both of these seem to leak into the car.
1helpful
2answers
I have a 2001 Chevy Monte Carlo SS. Everytime it rains I get standing water on the passenger side floor. I have changed the cabin air filter and it still is happening. Getting worse with every rain
Hi, very likely you have a leak from the wind shield and these can be proven or disproved by running tap water on the passenger side of the windshield. If the windshield is leaking a technician should be able to reseal the strip around the windshield or replace the windshield if its broken. Thank you for using fixya!
How do i remove the windshield wiper blade on my 2001 chevy monte carlo so that I can put new ones on?
kind of hard to explain,just go to a major Parts store , Advance, one of them will install them for FREE
1helpful
Windshield wipers are not working on a 2002 chevy monte carlo ss but I still hear the motor
Wipers work with switch off
The wiper motor is located under the panel at the base of the windshield. The wiper arms must come off to gain access.
Wiper fluid and odometer (96 Chev. Monte Carlo)
washer fluid is on the passanger side of car... is the odometer digtal or reg..with needle
1helpful
2answers
2004 chevy monte carlo,,,,rear defogger and windshield washer stopped working,,are they on the same fuze?
no, if your wipers are working then the pump has power,if you cannot hear the the washer pump working ,it will need replaced they are about $25.00 at Autozone,
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
