Question about Haier HWR08XC7 Air Conditioner
E1 Error on air conditioner
After a rainy day, the ac stopped on its own and displayed an E1 error. I ignored it and the ac turned on again, but soon after displayed the E1 error. The E1 error went away and worked, but blew warm air instead of cold, so I cleaned the filter. I have the ac on cool and the temp is set at 61. A few hours later, I decided to look online to troubleshoot the problem and unplugged the ac, but when I plugged it back in, the E1 error showed again and I couldn't do anything. I used the remote and and it worked again, but only blew warm air. The temperature that is displayed is stuck on 82 degrees, and just went up to 83, but then back to 82. I don't know what to do and it's really warm. Please help.
    New Friend:
  • 22 Answers
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Posted on Mar 25, 2017
3 Suggested Answers
6ya staff
SOURCE:
shinakpas
SOURCE: HELLER MOBILE AIR CONDITIONER
that's the way it should work, after you set temp to 20 degrees, display jump to the inside room temp in your case 25 or 29
Posted on Jun 14, 2010
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
SOURCE: E1 error code
Replace room sensor.
Posted on Jan 04, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
My air conditioner want turn on or anthing and it shows e1, whats this mean
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
Sep 15, 2013 | Haier HWR06XC7 Air Conditioner
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
E2 error code in samsung split AC
From all Samsung recomendations... if your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced.
If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced.
To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864) any day between 9:00 a.m. and 9:00 p.m. Have the model number and serial number of your air conditioner on hand when you call.
Hope helps.
Jun 29, 2011 | Samsung AS18A6RB Air Conditioner
E1 error code
my AC is going on 5-6 years, it's never failed me until the years. The Error E1 code hes been coming on lately.
i wait a few MIN's, then try again. about the 7-10 tries the unit comes on.
1. what is a error code 1
please reply to:
Derrick holiday
Email.... euphoricsounz@gmail.com
thank you.
dh
Aug 03, 2009 | Samsung AW1293L Air Conditioner
Error code E1 54 on samsung air conditioner split
A Bit of a late reply but E1 54, is indoor fan fault.
Dec 31, 2008 | Heating & Cooling
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
Haier HWR08XC7 Air Conditioner Logo
315 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bill Jennings
Bill Jennings
Level 1 Expert
Bart Walker
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
