LG LMV2083SW Microwave Oven Logo
A
Anonymous Posted on Aug 10, 2012
Tips on changing a door on an LG model MC 8483NL microwave oven
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 15, 2007
SOURCE: LG microwave oven
It's usually a bad door switch or a broken door switch mount. Once in a while it's due to a board problem. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 13, 2008
SOURCE: LG Convection Microwave Oven MC-7843D
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
In some brands there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • 54 Answers
  • Posted on Apr 24, 2009
SOURCE: I jus brought an LG microwave oven (MODEL
E-02 on the LED display.
That usually indicates a keyboard error...not a good thing...take it back and get a new one.
Anonymous
  • 109 Answers
  • Posted on Jun 16, 2009
SOURCE: LG Microwave MH-685HD Owner's Manual
Try this website: http://www.service-manual-owner.com/lg.html You may have to email the person to get the manual?
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 25, 2009
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
MICROWAVE MODEL 8083D MODEL MC8083D PLEASE SHOW THE INSTRUCTION MANUAL
Hi Denise, I send you the link to download the user manual of the Microwave LG
Regards Franco Dosil
Hola Denise, te env?o el link para que descargues el manual de usuario del Microondas LG
Saludos Franco Dosil
https://www.lg.com/za/support/support-product/lg-MC-8083D
I WANT THE MANUAL FOR MODEL MC 8083D
xx
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
Is this a magnetron problem?
check the H.V.capacitor first for a shorted condition,then the H.V. diode next these are a big culprit and are cheaper than a mag tube
21helpful
5answers
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Lost instruction manual
Hi - You can download the manual from the link below:
MC-924JLR
Please update the question & let us know if the information given was useful to you - Good Luck!
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
