Question about Armitron Watches
New watch won't start
How do I make a new watch start?
    New Friend:
  • 24 Answers
Maybe the battery is bad? If its new take it back to where ya bought it and tell them. Most places will replace of fix it. I would check the battery.
Posted on Aug 12, 2012
6ya staff
SOURCE:
Watch won't work after changing battery
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Apr 20, 2013 | Watches
How to remove back to change battery in "My Wish" Collezioni watch. No notch for knife and won't screw off.
You should be able to pry it off, just follow this simple steps:
Locate a very small tab (or recessed area) on the edge of the back cover. Pull out the stem, which releases the back on some watches.Get a small flathead screwdriver it needs to be a thin inflexible tip. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. These steps are listed on wikihow:
http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools . You also could skip step 2 if it's a cheap quartz watch.
Feb 19, 2013 | Collezio Collio Mens Watch
Just got a new Seiko watch but the date won't change automatically
Main cause would be that the date gear teeth have been stripped. This is done by setting the date whilst the hands are trying to change the date themselves (between 10pm and 2am). Always adjust the date with the hands around 6.0clock. You will need to return your watch to where you bought it for repair I'm afraid.
Jan 18, 2013 | Seiko watch - SXDA42 Watches SXDA42 Ladies
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Oct 01, 2012 | Tissot T-Touch T33759851
I'm able to set the time and date but once i push the crown back to its original place the watch doesn't start so i push the upper bumper and the seconds begin to run nevertheless the minutes never...
your watch is chronograph,. and it is not in the picture. probably your problem is the second hand won,t move, it is because that the sub dial on the lower part it is the real second hand. the big second hand is for the stopwatch. the to sub dial on the upper sides of your watch. the upper button/bumper is to start and stop the stopwatch or the big second hand and the bottom bumper/button is to reset it. i hope this can solve the problem...
Jul 25, 2011 | Swiss Army Wenger Sportedge Bracelet Watch
Hi i just bought a "the cannon" watch from west 49 and i don't know how to get the watch to actually start. i set the time on it but it won't start ticking. i'm wondering if it's...
Hi alec,
I see that you cannon watch is not ticking even after you have set the time.
Well after you set the time you push the knob back in once the time is set right then the watch should start ticking that instant.
If the watch is not ticking at all then it is either a damaged watch or the watch sold to you may not have batteries on it.
can you give me a model and info regarding the watch maybe we can get information or a manual about the watch for further checking before considering it to be broken.
Also if you can try calling or going back to where you purchased the watch maybe they give you details on why it will not click since you just bought it I believe they will assist you if it may need replacing.
I hope that this helps.
Have a nice day,
mvincentc
Jul 02, 2011 | Watches
Cracked glass tank mens
mcdevito75 here, Best bet, look for a smalll watch repair shop in your area, most likely they"ll have to order from Cartier the new crystal, approx. $75.00
Aug 07, 2010 | Cartier Watches
Replace battery for PULSAR Y911. how ro start it?
To restart the watch, you have to short the battery with a pin that sits under a sticker on the back of the watch. The sticker is supposed to explain that. You can usually do it with a pair of sharp scissors or tweezers. Without "jumpstarting" the watch, just installing a new battery won't start the watch. (I don't know why.)
Dec 04, 2009 | Pulsar Watches
Watches Logo
499 people viewed this question
Top Armitron Watches Experts
Janelle Schoonover
Janelle Schoonover
Thomas F. Schneider
Ekse
Are you an Armitron Watch Expert? Answer questions, earn points and help others
