Used scope. Eyepiece does not lock up tight, tends to wiggle loose and drop off. Easy fix? or expensive. Considering putting a rubber gasket in between the scope and the eyepiece in the hope it tightens up the connection.
Problem 2: the screw that is threaded to the quick release plate is too short-it does not lock up the plate tight to the scope. Longer screw will solve the problem?
