Frigidaire 30" Built-In Single Electric Convection Wall Oven - Black Logo
Bill Morrison Posted on Aug 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Probe light stays on. Doesn't turn off, even when you push probe button. Clock won't display, however oven still works.
  • Official Brand Answer 4,342 Answers
  • Posted on Aug 14, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466862
Points
5907
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
5 Related Answers
Anonymous
  • Posted on Nov 11, 2008
SOURCE: I have a Frigidaire 30" self cleaning oven that is a stand alone...the oven stopped working this past weekend
have your electronic timer sent for repairs, go on internet at ApplianceTomers.com
Anonymous
  • 145 Answers
  • Posted on Dec 12, 2008
SOURCE: oven wont work
If the sensor were bad, the unit would throw a fault code. On the back of the range, near the top, there should be a tech sheet for you to use to troubleshoot the range. It sounds like a thermal sensor may have opened up. Consult that tech sheet, it should point you in the right direction.
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Dec 29, 2008
SOURCE: "Pop"...now oven doesn't work.
power surge,,replace board
Anonymous
  • 1214 Answers
  • Posted on Jan 30, 2009
SOURCE: Digital oven temperate is wrong
Yes, that is the probe that sends info to the controller.
If it's not bad, then the controller is, but normally it's the probe.
Check that the controller has not been incorrectly calibrated before you change the probe out, although most do not allow a swing of more than 15-20 degrees. Yours may allow more though.
I am guessing you measured the actual temperature, to the set point temperature, with a know good thermometer.
Anonymous
  • 10865 Answers
  • Posted on May 20, 2009
SOURCE: door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Frigidaire stove
Power outage could have shorted out the control panel. Call the power company and put in a claim with your insurance company. Tis happened to me & I was able to reset the oven, even with a glowing bright & dim panel. Thought everything was ok but the upper oven doesn't stay on & the oven probe doesn't work, but it's too late for me to file a claim.
2answers
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
The probe doesn't work on my JT912 GE wall oven
Test Continunity for your Probe, if it has good continuity, then you have a internal issue with the Oven... More than likely, you are going to need a Technician
4helpful
2answers
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
1helpful
2answers
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
11helpful
6answers
Probe light stays on so I can't cook
After calling an authorized technician and the thermador support line, neither of which solved my problem, i was told a HARD RESET of the PROBE is all that is required. This problem originally occurred on my Thermador double oven after a power outage and rendered my oven unusable b/c the probe light would not go off -- even though i had never used the probe!
To hard reset the PROBE, turn off the oven at the breaker box, plug in the probe for 1 minute and remove it, then turn the power back on at breaker box, and probe light goes off!! Also, since i didn't have the original probe and to buy a new one would be $80, I borrowed a friend's Thermador probe (different model but it still worked). It cost me $85 for the service visit, 2 weeks of nonoperational oven, and about 5 hours time -- hence the reason i am making this post. It is a golden trick!!
What did NOT work -- turning off power to house again for 15 minutes to reset the OVEN, and disconnecting the probe wires from control panel so probe isn't recognized.
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
