When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
If you have the owners manual look on page 64 and see what it says there about the light lighting up in the front of the unit. if you do not have the owners manual, you can get one for free here:
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/52-62HMX84_E_R1_093004.pdf
