How do i change the paper roll
SOURCE: Trying to change the tax buttons on my CASIO HR-150TER
I solved this problem..
1. press and hold your % Key the zero on your display will disappear While the % is pressed, press and hold your CA key. After a short delay the calculator will print a line #--------------- when this happens release the keys.
2. Enter your tax rate for me this was 7.75 then press your Tax+ key.
now your rate is set.
You can then use this key as normal. :)
Hope this helps.
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
SOURCE: Casio HR-150TER calculator fault -E appears on
Casio HR-150TER calculator fault -E appears on screen & will not print. Thank you
