SOURCE: air conditioner blowing out hot air?
you will have to get a dye injected into the system or have it checked witha freon probe
SOURCE: 2005 Kia Amanti; heater on driver side blowing cold
For those of you who may google this link and are looking for an solution, my local repair shop isolated my 2005 Amanti problem to a $2.78 plastic clip on the temperature blend door actuator rod linkage. It simply fatigued and eventually broke resulting in the actuator rod falling off the actuator door lever. The labor to isolate the problem and to replace the clip did amount to almost $170. Hope this helps those of you in the future.
SOURCE: The heater on my 1995
check the relays, fuses and thermostat. u will spot the issue in one of them.
SOURCE: what is p200a my check engine light is on 2011
Cheers,
I think the code you are referring to is P0200.
This code means your vehicle computer (PCM) has identified an issue within the Fuel Injector circuit.
Possible causes for P0200 code are:
SOURCE: driver side blowing hot air passenger side blowing cold air
I'm having the same problem except on mine it's the driver's side that's blowing cold. Do you have the pictures in a finer resolution? I can't make them out and when I zoom, they are too grainy. Does the replacement require removing the dashboard? What's the general cost of the acuators? Are they readily available at like NAPA or other parts stores?
