SHARP SJ-41M SJ-37M
SOURCE: I have a 4 door
From my search the only Sharp Regrigerators are sold in Australia and NZ. Here's the list of spare parts outlets:
State
Spare Parts Wholesalers
Contact Details
Queensland
Prime Electronics- Bowen Hills
24 Campbell Street
Bowen Hills QLD 4006
Phone: 07 3252 7466
Fax....: 07 3252 2862
Email: [email protected]
New South Wales
Prime Electronics- Flemington
185 Parramatta Road
Flemington NSW 2140
Phone:
02 9704 9000
Fax....: 02 9746 1197
South Australia
Statewide Appliance Spares
178 Sturt Street
Adelaide SA 5000
Phone: 08
8231 3369
Fax....: 08 8212 3195
Victoria
Speedy Spares
451 Macaulay Road
Kensington Vic 3031 G.B. Telespares
5 Hunt Crescent
Clarinda Vic 3169
Phone: 03
9376 1333
Fax....: 03 9376 7110
Email : [email protected] Phone: 03
9512 7604
Fax....: 03 9512 7534
Western Australia
WA Appliance Parts
135 Russell St
Morley
WA 6062
WA Appliance Parts
1/9 Blaikie St
Myaree WA 6154
Phone:
08 92754755
Fax:...: 08 9275 4935
Email :[email protected]
Phone: 08 9330 1999
Fax:..: 08 9330 1677
Regards and hope this was Helpful,
Worldvet
SOURCE: Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
SOURCE: IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
You have a defrost problem. You need either the defrost timer, defrost heater, or the defrost bi-metal. If you have a meter you can ohm out the heater and the bi-metal ( as lonh a s the bi -metal is frozen as it opens when it gets warm to cut out the defrost heater) if you have an ohm reading on either one of the two the replace the defrost timer, if you don't then replace the part that has no ohm reading.
SOURCE: Sharp SJ-42-WH self-defrosting fridge. Freezer
I recently had exactly the same problme with this model refrigerator. I found the problem to be the defrost timer. It is located behind the panel on the back of the refrigerator where the mains cord is located, you will need to replace it with the exact same model. I am in Australia and managed to find the exact part on ebay cheaply from a local appliance parts supplier, any appliance parts supplier that deals in Sharp refrigerators should be able to help you.
You will have to defrost the refrigerator overnight again before doing this repair.
Of course there are a couple of other components that could cause this problem, you can acutally check to see if the defrost time is moving by taking note of it's current position and then checking it every thirty minutes or so. If it does not move then it could be faulty, make sure also that power is getting to the timer as well.
SOURCE: sharp SJ-F80SP-BK 4 Door refrigerator
When the freezer section gets cold and reaches
its required cooling temperature, after that the frost on freezer section
starts defrosting and the cooling fan in the freezer section blows this cool
air from freezer to fridge. But if the defrost cycle does not start then over
ice will get collected on freezer ventilations and that will block the
air passing section from freezer to fridge, so the freezer gets cool but fridge
section does not cool.Its defrost problem. Try
manual defrost by unplugging the refrigerator from main power outlet
for 4 hours then reconnect it and check, if the same problem is noticed again,.
If yes then its defrost board problem. The defrost board located in the back of
fridge section. You can get required parts from www.repairclinic.com or from
online sears part site. ------------- Thank you.
