Viking DFUD142 Built-in Dishwasher Logo
Richard Reiner Posted on Aug 10, 2012
Standing water Viking dishwasher
We have a Viking Viking DW20.3 which has stopped functioning. There is standing water inside. It is 4 years old and we are told it needs a new computer. Could this be right? The computer plus installation is 70% of the cost of the dishwasher new.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
914
Points
6
Try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
1helpful
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 • Dishwashers
14helpful
3answers
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Dishwasher not getting hot or drying
Same Problem Here - I Noticed your Post is quite old - Please did you solve the problem my friend..........???
[email protected]
3answers
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
6helpful
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Leaking Kenmore dishwasher
if you are very careful you can reseal it with a soldering iron as it should be a sealed cabinet. i have seen one seald with a cheap sealr and the cabinet turned orange.
2helpful
Ge dishwasher
If your GE dishwasher is between 5-10 years old, you may try replacing the check valve piston & nut assy (about $14). It's located on the inside in the rear of the dishwasher behind a screen which is fastened by about 4 screws. Once the screen is off, you can easily unscrew the check valve assy by hand ... install the new check valve assy ... reinstall the screen with the 4 screws ... and save yourself $400 for a new dishwasher.
Apparently, the rubber cone in the check valve assy deteriorates over time and prevents the pump from fully draining all the water from the bottom of the d/w at the end of a cycle.
GOOD LUCK!!
Feb 02, 2008 • Dishwashers
Top Viking Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
