SOURCE: Green Wavy Lines, and lower Convergence Issue
Before you call for help is a good idea if you check the solder conections to the convergence Ic's and resoldered them and while you are there check and resoldered any overheated areas.If the soldereing corrects the problem you will not have to worry about convergence adjustments,as long as the set is unplug you can carefully work in the chassis without having to touch the anodes of the picture tubes,stay away from them.Lets us know how it goes.
SOURCE: ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
SOURCE: Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
SOURCE: Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
SOURCE: Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Testimonial: "I appreciate the detailed response. I will try your suggestion and let you know how it works. Take care."
