SOURCE: There is no heat when using multi-rack convection function on the GE Monogram double wall oven
this is a job for a serviceman as your hi-limit switch has failed
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct". This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash. The grease is now a hard rubbery coating on the surface of the rack. To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good. Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth. Turn on to 450deg for 30 min. Much safer, less costly. Please acknowledge this posted solution if helpful. Have more info if needed- Thanks -Ed
SOURCE: We have a GE XL 44. The oven won't heat up at
sounds like a bad control panel , I bet it is a touch button type if it is get all the info off unit and order control panel here http://www.appliancepartspros.com/
SOURCE: ge profile oven lock button won't go off
1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door. 2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle. 3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad. or 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers. 2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time. 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off. 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down. 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
